Question about Sony Playstation 3 (PS3) Console
PS3 is "on", red screen has occurred with a error warning
I turned my 180 Gb PS3 and instead of normal screen I've received red screen with a warning message " A serious error has occurred. Contact technical support for assistance." written in different languages. How do I fix this problem?
  • murahovich Jul 27, 2009
    when I turn on my PS3, normal screen appears, but only for a second. and another thing controllers seems work OK, I can turn on and off PS3 using controllers.
  • crispy_ninja May 11, 2010
    I'm having a similar problem. If I find out anything I'll let you know what worked for me.
This is probably an warning about problems with your hardware (such as gpu or ram modules) .
The only thing you can do is taking the system to an assistance centre for hardware checking, they will test all the components of the system .
if your system is covered by warranty, don't waste time and call sony as soon as you can !!
unfortunately, there isn't any firmware solution to fix it, because all system functionality is prejudiced.
the only thing you can do (i belive it wont work), is reseting av settings by holding the on;off button when starting up the system .
Posted on Jul 27, 2009
An incomplete red ring circle appeared
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case.
Nov 30, 2010 | Microsoft Xbox 360 Console
Red screen
The "Red Screen of Death" usually happens in later PS3 Fat models right after you have turned on the PS3. It can happen right after the PS3 logo and wave animation appears. It is a mysterious error that seem to be software related during the checking process (perhaps some corruption in nand flash or harddrive block). When the error occurs, the screen turns red, and you see a message:
Oct 09, 2010 | Sony PlayStationĀ® 3 (80GB) Console
My screen appears red, asking for technical support.
Hi Ernesto,
If you are getting this error it is called the no display error.
Cause:
The reason that it happens is because the GPU which deals with all of your graphics has overheated. You just need to stop the heat build up in order to make it work again.
Solution:
The first way you can fix the No Display Error is by sending it in but bear in mind for this problem there is a $150 charge for the repair which is pretty steep!
Alternative Solution That Is Faster:
If you want to get the problem fixed EVEN FASTER than the option for you is a good PS3 Repair Guide.
NOTE: MAKE SURE You Check Out A Complete Review Of The Top PS3 Repair Guides First!
Oct 08, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: when i turn on my ps3 a red screen appears and say...
What is the code? i have a guide I can help you. Shoot me an IM on AIM
DBurch1102
May 18, 2010 | Sony Playstation 3 (PS3) Console
Red screen: "a serious error has occured"
This is called the "PS3 Red Screen Of Death" it's the same as the 360's RROD. The best solution would be to contact Sony about it and they should resolve the issue.
Jan 09, 2010 | Sony Playstation 3 (PS3) Console
My xbox360 has a red circle instead of a green circle theirfore will not work what can this be
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death"), represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off.
Distinct from the General Hardware Failure is a similar-looking error warning where four red lights appear, in which case the console does not detect an AV cable is plugged in. The four lights can sometimes also be seen when power surges or very brief power outages occur while the console is running, in which the console needs to be unplugged and plugged back in again to reset the error. Two red lights appear when the system is overheated.
Oct 06, 2009 | Microsoft Xbox 360 Console
When i turn on ps3 its a red screen that says eror occured
check on the ps3 and if an orange light is flashing then you have the "flash of death"  its the same thing as the rings of death on the xbox 360 you are going to need to go get it repaired its about 40-60 bucks not sure.  you can also reset the whole thing by hold the power button in the front down and hold for about 30-40 secs if that doesn't work the its option 1 or you should get it check out before going to get it fixed
Apr 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,356 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
