Question about Dell 3100cn Laser Printer
Error 016-302 on Dell 3100cn
I have an error asking to restart the printer but this makes no difference.
  • 6 more comments
  • Anonymous Dec 18, 2007
    Same problem tried shutting prt down ~ 1 min then power up... same error.
  • th3 c14w May 27, 2008
    I have the Dell 3100cn printer in operation for only 27 months. Overnight it appeared with the error code 016-302 restart printer!. I have called Dell customer service. They advised me it is a common error with the board located on the left side which then needs to be replaced at the cost of $307.99 PLUS LABOR. I have tried to power off/on, unplug all cables, unplug all wires from the board on left side. After doing this it looked promissing but it then continually read "processing" and got really hot.
  • alex5292 Jun 19, 2008
    I am having the same problem, Restart Printer error message. Tried all of the above... any suggestions Dell?
  • Anonymous Jun 19, 2008
    Same problem, 2nd time. The first time the motherboard was replaced by Dell.
  • Anonymous Jun 30, 2008
    Same here...
  • kwhitney714 Jul 07, 2008
    As with a previous user, my printer suddenly displayed "016-302 Restart and if same display, report to service." I also tried several self-help remedies (unplugging, changing outlets, and connector), but the same message reappeared. I called Dell, and the tech directed me to unplug and re-seat three connectors to the motherboard. It did not help. I have less than 7,000 copies on this machine. I had an unusually early message to change the primary drum. I have spent a fortune on this machine, so I do not intend to replace it. Everything (toner, drum) is new, but these costs are sunk costs. I will likely trash the machine.
  • naci9726 Sep 18, 2008
    i have the same problem this printer was given to me for free. starting a small home based business. it was working fantastic until i got this message. i see noone got a resolution except i read one guy dell told him the motherboard on the left side had to be replaced for $300 and something dollars.
    any additional info please keep me posted 917-826-0705 cell in ny or naci9726@juno.com.
    Al
  • Anonymous Nov 15, 2008
    Yep, it got me too.  Has anyone solved this?
Drum cartridge replace soon
Posted on Oct 30, 2008
Error code 016-370 Restart printer If problem
Error code: 016-370
This is yet another error message asking you to restart the printer. You need to switch off the printer and then connect it via the USB cable. Press the hold and cancel buttons simultaneously. Then power on the printer again. On your LCD display you should typically see a message saying 'ready for download mode'. You will then need to initialize the firmware update process. LCD will change to the writing mode. 10 minutes later you will be prompted to start the printer again.
The firmware is available here:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R148843&SystemID=PRN_LSR_3100CN&servicetag=&os=WLH&osl=en&deviceid=6673&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=40&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=197745
May 02, 2011 | Dell 3100cn Laser Printer
I'm getting the following error: Dell 3100cn Laser Printer error 004 332 problems
Try restarting your printer, if this does not help make sure that the toner cartridges are set in properly and locked in place.
Mar 28, 2011 | Dell 3100cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
004321 restart printer error
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
Nov 30, 2010 | Dell 3100cn Laser Printer
Get error message "004-321 Restart printer" Have tried everything.
this is a 'reseat drum' message. If you do that and make sure all is clean then restart it should be fine.
Sep 12, 2010 | Dell 3100cn Laser Printer
Getting 004-332 restart error
Hi
Error code: 004-332
1. This type of error code implies that you need to restart the printer again.
2. However, do check to see if toner cartridges are seated in the proper position.
3. Also ensure that they have been locked in.
Jul 14, 2010 | Dell 3010cn Laser Printer
Dell 3130cn gone down with repeating 016-370 Error...
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer. Please let me know the results.
Jun 28, 2010 | Dell 3100cn Laser Printer
We are getting error code 004-332 Restart Printer on our Dell 3100cn printer. We have tried unplugging and restarting print spooler but it still come up witht message when we try to print
Hi
This error code on Dell 3100CN occurs when toner cartridges are not seated properly and/or are not properly locked in. Turn off the printer and unplug it. Now, you need to open the front door and pull out the drum. Try moving the carousel and check if it moves freely. While moving the carousel back and forth try adjusting the cartridges. try to unlock the cartridges and lock them again.
Now turn off the printer and turn it on after 1-2 min.s.
Daniel Scott
Jun 24, 2010 | Dell 3100cn Laser Printer
Error code 004-332 restart printer. Paper not
Check to see if your toner cаrtridges аre in the right position and locked in place. Then, stаrt the printer аgаin.
Jun 30, 2009 | Dell 3100cn Laser Printer
My Dell 3100cn will not print unless I press Init NVRAM and restart printer every time I want to print. This is annoying. Can you help? Thanks! Greg
this implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
rate my answer
Aug 22, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
6,975 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
