Question about Coleman Heating & Cooling
Compressor will not fire suspect caps how to troubleshoot
    President:
  • 1,922 Answers
How old is unit,or i missed it.,caps are a great non compressor start,some caps are "dual-caps" one is for comp and other is for fan,will have 3 terms in that case,they are a good investment if unit is over 5yrs old,they're not cheap,can you put a ("headset")manifold gauge set on and see if low on refrigerant,that will cause same problem/fan but no a/c compressor
Posted on Jul 27, 2009
Truck was stalling.cleaned the egr valve and it ran fine.
just a thought the plug leads are in the right order on the cap, your not firing out of order at all are you.
Mar 24, 2015 | Subaru 1989 XT A/c Compressor
I used compressor 3 wks ago and worked great.Now will not compress air above 25 psi.changed regulator OK,removed air intake filter,it has suchion.removed outlet tube,bloweds air.Oil in site glass.I did...
Mike:
If you have air blowing out of the oil filler cap, I would suspect that the piston rings are shot. The piston rings are supposed to keep the compressed air above the piston, and air seems to be leaking past the piston rings into the crank case.
Sep 17, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Every thing runs but the compressor wont fire i think its the compressor start up capacitor how do i test the capacitor
first discharge the capacitor for safetys sake,then touch the meter leads of a multi-meter set to RX100 to the caps leads if the needle stays on 0 the cap is shorted(but that would trip the wall breaker),if it doesnt move at all its open,if it goes to 0 and slowly climbs back towards infinity its good,i believe you will find the ptc overload relay on the compressor is defective,its in combination with the capacitor,the cap is only on there to take the power spikes off the relay contacts during start-up,the ptc overload relay is what aids in compressor start-up/run/and overload protection if compressor wont fire,change them both and it will run
Mar 22, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
We pulled and replaced spark plugs and distributor cap on a 1985 Nissan Z24 Engine - started once before without cap on but now will not fire again. I need firing settings for distributor and knowlege of...
It started without the distributor cap? That is impossible. I suspect you may have plug wires mixed up. Make sure it is wired as the diagram shows. Also replace the rotor. clay58_39.png
Mar 18, 2011 | 1985 Nissan Pickup
Fix my powerhose for 1988 acura integra
Integras are known for igniter assembly failure. Depending on engine year and model may be located inside of distributor or on inner fender well.
Check for spark at spark plugs, if no spark and cap and rotor o.k. suspect igniter. If you have spark check for fuel pressure with test guage, if fuel present, check to see if injectors are firing. (noid light will prove this out). If injectors not firing suspect camshaft position sensor.
If no fuel pressure suspect fuel pump or clogged filter.
Good luck and do rate this solution.
Mar 19, 2010 | 1988 Acura Integra
Air cond outside unit will not run
cap or hi resistance on the contactors on compressor
Jul 29, 2009 | Heating & Cooling
Outside unit not operating. Outdoor Unit fan (fan
the fan motor is burt. replace it. it will still spin if you manually engage but it will overheat an may even cause fire, also that waste tremendous amount of electricity now.cap is not defective,
Jul 04, 2009 | Heating & Cooling
Paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Oct 22, 2008 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
