Question about Indesit W 123 Front Load Washer
Indesit wd 125 had tripped a fuse switch
My washer dryer had tripped a fuse switch in electrical cupboard and will not turn on.not sure wether to throw it out or get it fixed,has anyone had this problem and what could be the cause of the problem
  • 1 more comment
  • lynste_talla Jul 27, 2009
    hi,breaker is fine,and stays on ,but washing machine will not go on,i have replace 13amp fuse in plug and tried it,still no power on???
  • Bruce Hathcock May 11, 2010
    first un plug it and reset the breaker, does the breaker stay on? yes? then plug it on does the breaker star on? yes? trun maching on breaker go off? Yes? replace breaker $10.00 bucks how old is the breaker and have you checked to see if the wires have come loose. they will over time.
  • 28 Answers
So many reasons. Check electronic board, loose cables, power inlet inside the chassie (noise cond).
Posted on Jul 27, 2009
Indesit idc85 will not work or heat up
follow this steps and fix it. God bless you
. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gWEW0sFp
Oct 01, 2013 | Indesit Dryers
When you turn the dial and hit the on switch it trips the electric
sounds like heater element gone check it first its on the back
Jul 15, 2012 | Indesit IS70C Electric Dryer
My dryer trips my electric when i switch it on
this will be either the motor or control has shorted
Apr 20, 2012 | Indesit IS70C Electric Dryer
My indesit widl 126 is not drying (no heat )
If electric, check the following areas.
1. No power to the dryer
2. Heating element
3. Thermal fuse
If gas, check the following areas.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective
Jul 09, 2009 | Indesit WA 125 Front Load Washer
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Washer and dryer won't run the washer will only fill
Hope this may help;
DON'T FORGET TO RATE:
Regards,
VOTIT
Sep 06, 2008 | Maytag LSE7806A Top Load Stacked...
Red light padlock symbol? what does it mean
the padlock led indicates that bthe door is open or poss interlock fault, however since you said it now trips fuses, IF you are not electrically minded call an expert something could of become disconnected or moisture could of got into the machine and blown the module
Jan 09, 2007 | Indesit WA 125 Front Load Washer
Indesit W 123 Front Load Washer Logo
439 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
