Question about Microsoft SQL Server Standard Edition for PC
MSSQL Related Problems
Please do help me with the configuration of my MSSQL 2005Sever. I always receive this message: Warning: mssql_connect() [function.mssql-connect]: Unable to connect to server: localhost in C:\wamp\www\test.php on line 6
This error comes from connect test code I created. (Below for more details)
MS SQL2000 Connection Test
$connection = mssql_connect( "localhost","sa","4321")
or die ( "Sorry - unable to connect to MS SQL2005" );
echo( "Congratulations, you connected to MS SQL2005" );
I am using wampp server (Includes php5, apache, and mysql) I enable mssql on settings since that is the database that I am using.
Most probably the problem is on ODBC. I cannot connect to mssql on it.
Anybody would help me with this?
  • 244 Answers
Please see link below
Basic tutorial in connection PHP Language to MS SQL Server.
Please rate me SOLVED.
Posted on Nov 23, 2007
AIT-3 Tape Ejects when they put in MSSQL 4027
You will not find the list of the error codes on the internet. I know that Error Code: 0x81 is a "Reel" problem as I was just told by Sony Support. You should call them, have you serial number at hand when you do so. Check for a Telephone contact number.
Good luck, Bruno
Jul 15, 2011 | Sony (LIB81A3BB) AIT-3 Tape Drive
How to connect my MSSQL server through VPN by using PPTP
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
Jan 20, 2008 | Cyberguard SG300 (00852503000366) Firewall
I get ''SQLDUMPER LIbrary failed initialization'' when i start the computer
SQLDUMPER is an accessory for Microsoft SQL Server that will allow you to track down problems with MSSQL. There's no need for it on your system if you're not using SQL Server.
Using Control Panel, select [Add or Remove Programs], then select the [Microsoft SQL Server] program and click on the remove button.
If you want to reinstall it, you can go to and get a new copy, but if you're not using it and no programs you are using are, there's no reason to have it.
May 26, 2011 | Microsoft Windows XP Professional for PC
Adodc1.RecordSource = ''Select * from wharfdb where entrydate>='' & ''''' & strdate1 & ''''' DataGrid1.Refresh Set DataGrid1.DataSource = Adodc2 Adodc1.Refresh DataGrid1.Refresh BUT SAME...
I think this can be the solution.
Adodc1.RecordSource = "Select * from wharfdb where entrydate>='" & strdate1 & "'"
Set DataGrid1.DataSource = Adodc1.Recordset
To see how the first statement is written, see down below.
entrydate > = ' " & strdate1 & " ' "
I hope this works for you.
Jul 08, 2009 | Computers & Internet
Windows Mobile Device connection problems to SQL
nope. you just connect your mobile device with active sync.
then to connect use this conenction string
Data Source = YourServerIP,1433; Initial Catalog=YourDatabase; uid=YourUsername; password=YourPassword
1433 is the port number of sql. You can change this if you like
Apr 17, 2009 | Symbol MC9060 Portable Terminal
I want searching code for visual basic 2008....which can search the required information from a my case database is FIR...if i input the FIR number..i want to show the correspoding...
Not much code needed in Visual Basic for this one. Visual Basic would only show the data actually. The search on the database is actually just one query statement. query = Select * from databasename.tablename where FIRnumber=?. where ? is the input in a textbox.
Apr 02, 2009 | Computers & Internet
Lost MSDE 2000 A Desktop Server
Default MSSQL-instance is sufficient if you do not have any other MSSQL instance installed. You can keep password as sa.
If you have any other queries then please feel free to ask here.
Mar 23, 2009 | Computers & Internet
Lost MSSQL Desktop Server
Here are a couple of things for you. First is a link to download MSDE 2000A:
Second, MS also has SQL Server 2008 Express available at:
Both are free downloads. The 2008 is a small downloader that will connect and download\install the full application.
Hope this helps. Please let me know how it works out for you. ~ Spoem
Hibernate configuration with windows authentication
When you login to your database (download the management tool) right click on server name->properties->security.
There you can choose mixed authentication.
Sep 05, 2008 | Computers & Internet
BCM Problem ... Lost Contacts
The BCM uninstallation doesn't delete your databases. They should still be on your computer here:
C:\Documents and Settings\<username>\Local Settings\Application
With either a *.mdf or *.ldf extension. Those are SQL databases which you can get the data off and into a CSV file which you can import into outlook (of course technical expertise is needed) or you could more easily (once the problem with BCM is resolved), make BCM re-recognize the databases by following these instructions:
1. Go into BCM and create a new database. That database needs to match the
name of the .MDF file. So if the MDF file is named "MyBusiness.MDF", create
a new BCM Database with that name
2. Stop the MSSQL$MICROSOFTSMLBIZ Server by going to Start > Run >
services.msc and selecting the MSSQL$MICROSOFTSMLBIZ service
3. Copy the original .mdf & .ldf files over the blank database. They should
be in the following location
Data\Microsoft\Business Contact Manager
4. Start the Server again (see step 2)
5. Restart BCM and see if you can access your data
which I found here (credit to Larry from the Lockergnome's forums).
If you could write what the error message is I could possibly help you resolve the BCM problem you're having, thereby making it easier for you to view the data on the SQL database files.
Dec 31, 2007 | Microsoft Outlook 2003 for PC
Microsoft SQL Server Standard Edition for PC Logo
153 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
