Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Printer was jammed jam was removed doubled checked still says jam
I have checked, triple checked...still says jam
    President:
  • 3,085 Answers
Open the door on the rear door of the printer and look.
Posted on Jul 27, 2009
How do I clear the Jam error code on my printer. There is no paper jam
Problem in cleaning Assemblyl(ink drainage system)right hand side..some plastic clutch activator knob is not moving L/R....which couse sticking cleang unit frwd/backward
Jan 23, 2015 | HP Photosmart C6180 All-In-One InkJet...
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
Windscreen washers not working, obviously has water in the bottle. fuses seem ok and cannot find the electric motor for the pump.
Look for a triple joint under the hood, where left and right one separate. Detach the hose coming from the pump, clean the triple's end and blow to ensure that the the wipers are not jammed. Check the filter as well, should be at the bottle, end of hose, if any at all. The pump together with its wires is probably hidden on the back of the bottle, you will find it by the wires.
Nov 10, 2009 | Hyundai Motor 1995 Accent
All of a sudden it is telling me I have a paper jam when I try to fax out. All the pages go through but after the last page goes through the machine runs just a little longer, then tells me there is a...
restart it... try this after you turn it off unplug it then hold down the power button for 30sec. and then plug it back in and restart it... I hope this works. what are you trying to do is to get rid of all the static in the printer chips which could trigger this problem. good luck
Sep 17, 2009 | Brother MFC-8860DN Printer
Mine wont pick up
filters are internal and if blocked will affect air flow. Check brushes in the foot not jammed or wrapped in hair
Sep 13, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Haveing problems removing the forks on a harley davidson
you remove the axle 1st
the 2 large nuts on the top of triple tree next
on the lower portion of triple tree there is a bolt on each side remove it
the fork tubes should pull down and out
remove the top of triple trees
remove the cover in middle of triple tree under it you will find a loch nut and a special spannner nut remove both topp triple tree will come of
unlock triple tree twist lower tree it should slide out
reverse to install
Sep 04, 2009 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Paper jam
Remove the platen cover located on the back panel and look up in there with a flashlight. Make triple sure that there is not even a shred or tiny scrap of paper caught in anything. Also try www.hp.com. Hope this helps.
Jan 29, 2009 | HP PSC 2410 All-In-One InkJet Printer
Paper Jam Error
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 14, 2007 | Canon PIXMA iP1600 Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
