Question about Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A/37 has horizontal lines thru the picture
My Philips 42PF7320A/37 has full picture and sound, but also has six equal horizontal bands through the picture. Each band (except the 5th one down) contains 16 horizontal lines that appear to be misplaced from other parts of the picture. Which board should I replace?
  • Philips Master
  • 19,396 Answers
To start , ensure that the problem does not depend on sygnal input (from description it does not look this way, but you never know). Test different inputs using different cables.
If the lines are moving, then it is a voltage drop. Since volts is applied at different heights on the plasma panel, a voltage drop can cause colored lines that move across the screen. In this case, a defective voltage regulator, a faulty cable to plasma screen , or a defective sustain board can cause the problem.
If instead the picture has static bands, and they come up always in the same position, scrambling the image, then you may also have a problem on main digital controlled board, where the video signal is generated.
In that case testing will be more complex, and there is need to follow indications on service manual to test the chipsets on board.
Boards that must be tested are Logic main, Y main, ribbon cable to Y main, Y buffers (both), all ribbon cables between this boards.
Also a diagnostic procedure from service menu can help in finding the fault.
See testing diagrams at page 26, and parts location starting at page 7 of service manual below:
Service manual available here.
Regards.
Posted on Jul 27, 2009
This TV has been in use for 2 years. None of the cables have been changed or removed. Apparently hit a button on the remote that blanked the picture & sound. I have a gray screen with menu options,...
Hi Jim:
You can find an owners manual on the Philips site.
There's also a quick start guide and a firmware update.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7320A/37&scy=us&slg=en
Try the above link, should take you to the site..or you can
do a google search....
owners manual Philips 42PF7320A/42
you should see this link in the list of links...maybe the top one.
42PF7320A/37 Philips flat HDTV 42PF7320A 42" plasma digital cable ...
May 25, 2007 ... Philips flat HDTV 42PF7320A 42" plasma digital cable ready with Pixel Plus ... Manuals & documentation · Leaflet · User manual · Quick start guide. + More Manuals and Documentation ...
Hope this helped.
Dec 27, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Philips lcd tv blinking 7 times no picture. 42pf7320a/37. no picture will not power up
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 12, 2010 | Philips Televison & Video
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
Why do i have red lines on my philips plasma tv?
if the lines are going horizontally across and look like someone took a thin magic marker and marked across the screen, you have one of two problems, either some scan ic's have failed or you have a flex cable coming loose from the panel. Either way it will require repair. If it is the flex cable the cost to repair will be beyond the tv's worth because the whole panel needs to be changed to fix this. If it turns out to be the scan ic's, they can be changed or the board the ic's are on may be changed depending on how the repair is approched by the tech. But the cost would be reasonable around 200 to 250.
Good luck
Sep 03, 2009 | Philips 42HF7444T 42 in. Plasma TV
Not getting full pic on certain channels
I've seen this problem before. Try to adjust the horizontal settings in the tv. you should be able to adjust the picture up just a bit and it will get rid of the lines. also if you are hooked up thru component or hdmi you should be able to press the # button on your time warner remote to fill the screen. Hope this helps.
Feb 10, 2009 | Philips Magnavox 42MF521D/37 Television
This set is a HD plasma tv and convergence is done differently than the rear projection tv's,rear projection tv's have convergence Ic's and you can adjust the color but not on this unit.
Nov 23, 2008 | Televison & Video
My Plasma TV is not working any more
Sounds like a scan problem if yu suspect the y-sus i suggs\est changing the drivers to
Nov 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
REPAIR NEEDED
sounds like the Y boards.best to replace all 3 at same time main and buffer upper and lower
http://www.shopjimmy.com/searchparts.cfm?make=Philips
Jul 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 42PF7320A/37 picture has horizontal lines and color splotches
Thanks for the email> I solved it by calling Phillips again and asking them what happened to the part that has yet to come its been a year! There is a saying we Dutch are proud of "If it ain't Dutch it ain't Much" Not in this case> My wooden shoes are looking good for throwing at the TV if they dont do something soon>
Aurora T-Z
Apr 26, 2008 | Philips Televison & Video
Philips 42PF7320A 42 in. Plasma HDTV Logo
436 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
