Question about Olympia Office Equipment & Supplies
I've lost my key for olympia cm70 where else can i get one?
Hi there, I have a Olympia CM70 cash register and I dont have a key for the cash draw and it is locked.I How do I get a key made for it? I only have the keys for the actual til Thank You Leigh-Anne
Hi. You can't get keys cut as there are no blanks for cash registers. You just buy one from a dealer or you can unscrew the bottom from the drawer and remove the tray, then bend the lock tab so it never locks again.
Jan 23, 2017 | Retail Supplies
My Olympia CM70's keys are lost. What can I do?
Those keys are universally common. You can even use any Samsung,Sam4s,or Tec keys. Or alternatively call any dealer.
Jan 30, 2015 | Retail Supplies
Olympia ap 1000 manual
You may download a copy of the manual here.
Feb 03, 2013 | Olympia CDP 24201 Cordless Phone
Please identify correct ribbon for Olympia De Luxe Portable
The European models used the DIN spool that has a larger center hole than the U.S. models
DickyO
Jun 06, 2012 | Olympia Office Equipment & Supplies
My olympia electric typewriter is always on capital letters no matter how i unlock the keys/shift...won't go back to small letters.
You didn't give a model but there should be a key that says above or on the front of it caps or caps lock the code and that key should do it.
DickyO
Jun 24, 2011 | Olympia Office Equipment & Supplies
Olympia Supertype 330 purchased August 2003. Gets little use. The right margin seems to be locked close to the left margin.
Go to the margin press but don't hold the mar rel key space or backspace to desired location press R. margin key.
DickyO
Apr 15, 2011 | Olympia Office Equipment & Supplies
The point from which you type is stuck in the middle and I cannot get it to realign to the left hand side
The Olympia 330 is the same as the Nakajima AE-830. if you have lost your operators manual you can download the Nakajima version from WWW.NADIST.COM.
First just try resetting your tabs. If that dosn't work, you can reset to factory settings by doing the following...
SwitchPower OFF. While holding down the MARGIN RELEASE KEY switch the power back on...the machine will start printing a self-test page...let it run for about 10secs then switch the machine back OFF. wAIT 10 SECS then switch back On and the unit should be back to factory default settings. ** Note..this will also clear anything in memory.
Sep 21, 2010 | Olympia Supertype 330 Typewriter
Where is the correction key on the olympia mastertype 2?
The correction key should be right above the return key.
DickyO
Aug 03, 2009 | Olympia Mastertype 3 Typewriter
Olympia Traveller de Luxe: ribbon not lifting as key strikes.
Hi, The most common cause for this problem is that the colour selection lever is set on white. Try setting it to Black or Red and see if that solves the problem. Ralph, Dial A Ribbon.
Jul 12, 2009 | Olympia Office Equipment & Supplies
66 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
