Question about Intel AAVID Pentium III Dual Cooling Fan - For Slot 1 SECC 2 Cooling Fan
Not properly booting,and no display - Intel AAVID Pentium III Dual Cooling Fan - For Slot 1 SECC 2 Cooling Fan
  • 89 Answers
Your ram have moved remove it and place it again it works
Posted on Jul 29, 2009
My pc is not booting
Hi eric,
Try connecting your laptop to a different monitor to see if it works properly. If it does, then there is most likely a problem with the laptop display assembly. If the external monitor does not work, then the problem may lie with the laptop's video card.
If you power on the computer and the display is black, make sure the computer is booting up. You can do so by checking the LED lights, listening to the fan, and/or listening for the Windows boot up sound. If either of these are functioning properly, your screen may not be working properly. You may take a look at ourToshiba Satellite LCD installation guide to help you replace the screen.Hope this solves your problem please rate my solution if it helped you.
Note:-Make sure that you are careful while working with the screen or Motherboard as there may be chances of shock if you are a novice i recommend to get it serviced by a professional.
Regards,
bonefirediv.
Apr 18, 2014 | Toshiba Satellite Computers & Internet
Gateway 8708 computer fan stars and powers on but no display
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 16, 2012 | Computers & Internet
The system boots normally but does not display on the monitor, what is the way forward
If it boots normally and there is no display on the monitor,it could be
1.Your Display card could have failed or the VGA cable from the display adapter is not connected properly to your monitor- In this case you will see a "no signal" message on your monitor.
2.If the monitor is powered on nothing appears,then your monitor most likely failed.
3.If the monitor's power on led light is not lit,then make sure your monitor is plugged in properly to the power source.
Oct 27, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
Blank computer screen 3 times out of 4 when booting computer
there must be the problem of your lcd backlight chek that properly by open it or tack it to the engg.near you.
Jan 27, 2010 | Samsung 226BW Monitor
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
Sep 02, 2009 | Computers & Internet
My acer aspire 4530 has always be given a distorted display can someone help me resolve this problem?
For, distorted display problem there are 2 possibilities
1> your display drivers are not installed properly so try to remove or uninstall driver from device manager and add & remove program and than install proper drivers
2> if the distorted display is from boot screen than its definately a RAM problem so kindly remove it and refit it properly and if still problem continues than kindly replace it.
Dec 19, 2008 | Computers & Internet
Booting problems.
try right click desktop go to properties/display setting check that display is set properly go to advanced settings check out there if everything OK go to control panel/device drivers uninstall video drivers reboot it should boot with standard vga drivers check if display is OK then try loading your proper video drivers
Jul 27, 2008 | Sony (B99860307) for VAIO PCG-K series...
My pc hard disc not initialised and no monitor display
kindly check your HDD's IDE if it is properly connected to your motherboard or better yet check your BIOS booting sys. use default booting sys.
Jul 23, 2008 | SanDisk Sansa m230 MP3 Player
Harddrive
Get into boot setup and change the 1st boot device as hard disk
Dec 30, 2007 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
