Question about IFB Washing Machines
How to remove error AC Lo error from IFB top load washing machine
SOURCE:
vest6
  • 196 Answers
SOURCE: Lint problems in a washing machine.
Most newer machines do not use lint screens. Instead the lint is pumped out during the spin cycle. If there is a build up of lint then I would suspect a restriction in the pump or the inner drum drain holes.
Posted on Jan 02, 2008
  • 126 Answers
SOURCE: Inglis washer LO-38002
any appliance parts store. it should be a stocked item.
Posted on Jan 12, 2008
SOURCE: How to use Rit Color Remover in front loading washing machine?
Try using the liquid version in/with the detergent or bleach section of detergent tray.
Posted on Sep 01, 2008
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
SOURCE: Top loading kenmore washing machine frozen water loaded
Could it be that it has overheated? My mom's washing machine isn't a kenmore, but it has a mechanism that causes it to stall when it is overheated from constant use. After about 15 minutes it cools off and starts again.
Posted on Aug 07, 2009
The machine has detected low line voltage. Correction requires connection to an adequate power source.
Jul 31, 2018 | IFB Washing Machines
My top loading machine of ifb shows lo A/C what is the fault can you help me
The voltage being applied to the machine is too low. Washing machine should be fed by a separate circuit of adequate capacity.
Jul 09, 2018 | IFB Washing Machines
Ifb machine is showing AC lo when i start the machine
Programming assignment help covers all computer programming subjects. Since students find difficulty in programming coursework due to high level complexity in coding part, lack of knowledge of technical concepts and practice. But don't worry our programmers help in writing best programming assignments and projects. Our Assignment help experts make you learn and skillful in the programming applications concepts both theoretically as well as practically.
Oct 05, 2016 | IFB Washing Machines
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
IFB washing machine front load Showing ' Lo' what
IFB washing machine top loader lo error what meaning
Aug 10, 2013 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
Dear, Sir in my IFB Washing...i got a Ac Lo error hiw i fix this Error washing stopped plez give reply sir
Sep 30, 2012 | IFB Washing Machines
Washing Machines Logo
1,146 people viewed this question
Top IFB Washing Machines Experts
Eric Sutherland
Ken Strite
Ken Strite
Raj Patel
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
