SOURCE: removing harley davidson ultra classic gas tank
Drain the fuel either by siphening or removing the cross over tube at the front of the tank and letting it drain that way or just block off those cross over lines and leave the fule in the tank for removal.
0) remove seat
1) drain fuel
2) undo cross over line (bottom front of gas tank.
3) shut off pet **** and remove fuel line from pet ****.
4)there should only be 2 bolts holding the tank on, one at the top front of the tank and one at the back of the tank.
All in all a pretty easy (but possibloy messy) job.
SOURCE: How do I change the front and rear brakes on a
Not too hard - Undo the two bolts on the caliper and then seperate the caliper and pull the old ones out. Insert the new ones and put the bolts back in to hold the caliper back together and then install them back on the bike with the two retaining bolts. Use a bit of lock tight (Blue) on the threads. Warning do not let anyone apply pressure on the brakes while you have them off the bike or you will have a mess and/or a problem.
SOURCE: 2002 harley davidson ultra classic setting the clock
Turn the Bike on and the Radio off and then follow the buttons on the screen. Most people think you have to do it while it is running and this does not work
SOURCE: starter removal on 2004 ultra classic harley davidson
Disconnect battery , remove the outer primary case, pull back the lock tab on the starter jackshaft, unbolt the retainer screw, then remove the two starter bolts from the right side, sometimes you need to loosen the oil tank mounts to get at these, slip the starter and coupler out as a unit, replace the coupler and jackshaft the same way they came out when the new starter goes in, install bolts , retighten the jackshaft bolt and bend over the retainer, install and fill primary case, connect battery thats it buddy
SOURCE: I need to know where the oil drain plug is on a
The oil pan is on the bottom of the transmission. Look under the transmission and you'll see two drain plugs. The one closest to the front left corner is the engine oil drain. The one closest to the center is the transmission drain.
Good Luck
Steve
Testimonial: "Thank you so much for your expert help. I am a new Harley owner and just needed a quick help to my problem. Thanks again. David Rieger"
