Question about Hotpoint Ultima WF860 Front Load Washer
Lcd display very dim and flickering
Every thing else works correctly and the there are no fault codes at!
I've put up with the same problem on my WD860 for nearly a year. The unit works fine - just the display flickers rapidly, goes very dim or goes off completely (one has to then guess and listen to the beeps to work out what its doing!).
Typically, the fault occurred shortly after the warranty expired. The 5 years parts warranty is a bit of a swizz - as you can only get the parts free if you pay for Hotpoint to fit it.
I did find a place that was offering a new display panel for just over £90.
After much Umming and Arring about ditching the entire machine or gambling on replacing parts (not knowing if it would fix the problem) I Googled the part number "Hotpoint hm0108" and found a place here in the UK (Nottingham) the sells recon parts.
(I won't give the name in case It's classed as advertising). You buy the replacement unit and send your faulty one back to them, which validate their warranty (I guess they recon your part to also sell on).
The display/control unit was just over £40.
Removing the display/panel is dead easy..
- Disconnect the power from the unit (Obviously)
- Remove the 2 screws at the back (from the little brackets). This allows the Lid to be removed. There seems to be a bit of a "knack" to removing the lid - otherwise you break a few little plastic clips!... With both hands push down and back firmly from the front, until the lid slides back about an Inch. Make sure its pushed back as far as it will go before you lift it up - other wise you'll hear the clips break and rattle down inside the unit (Mine did break, but the lid still screws back on fine, so they can't perform any major function!).
- On the display panel pinch the the row of bottom clips all the way along, to release the unit.
- The panel then hinges from the top and slides down and out.
- Remove the data/power Connector block (Which is keyed so that it only fits one way).
Repeat the process in reverse to install the new part.
Everything works a treat. I can now actually see what the unit is displaying!
I've fixed the problem and done my part for the enviroment - by recycling parts that Hotpoint don't make correctly!!... and not had to pay the earth (I think hotpoint wanted nearly £120 for a 2 min job!)... Everyone's a winner!
I have no idea what the actual problem was - obviously a design/manufacture fault with the LCD display unit.
I hope this helps?
(I'll probably never buy anything Hoitpoint again!)
Posted on Oct 14, 2009
  • linda253 Sep 14, 2013
    Thank you very much for taking the time to explain the remedy so well. I found your post very, very helpful
    President:
  • Hotpoint Master
  • 1,922 Answers
More than likely a bad or hi resistance ground,to board does everything work?just very dim read-out?
Posted on Jul 27, 2009
Need a new screen how much will it cost
This is a web site were you can buy the screen.
http://www.blisscomputers.net/hp-pavilion-g60-235dx-laptop-lcd-screen-16-wxga-glossy.aspx
Price:
$79.99 Make: HP Manufacturer Part No: G60-235DX Screen Size: 16 Inches Pixels: 1366 x 768
Good Luck!
Dec 03, 2009 | HP G60-235DX Notebook
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
Delphi XpressRC XM Radio backlight problem
Same thing happened to mine until it permanently went dark - no brightness. Problem is with the LCD display that is defective. As this model does not have a separate filament bulb unlike the non color model, it cannot be repaired. Likely too expensive to replace the color LCD display if avalaible. Next one I buy will be a non color version which has separate bulb.
Sep 17, 2009 | Delphi XpressRC XM Satellite Radio...
Dim display in samsung monitor
When the LCD monitor display is dim or flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 06, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
LCD monitor display troubleshooting benq e900wa
Check the video cable, make sure it is not loose. Try the monitor on another computer to see if it works.
If not then follow these instrucrions :-
www.lcdparts.net
Sep 06, 2009 | BenQ Computers & Internet
Samsung T220 Screen Flicker
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
www.lcdparts.net
Sep 03, 2009 | Computers & Internet
Acer aspire 4720z model laptop having dim resolution of monitor
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 23, 2009 | Acer Aspire 4720 Notebook
Presario 700 has a blank screen. Started occasionally going to a blank screen, now it stay blank. Will replacing the hard drive correct this problem?
If the laptop appears to boot up and the hard disk is spinning and the hard disk LED is flashing then the hard disk is OK.
Then the fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 16, 2009 | Compaq Presario 700 470024-192 Notebook
Toshiba a135-s4487 when on battery the lcd screen flickers and dims considerably.
When it first switches over to battery, you will generally see a flicker. The dimness is normal. Most laptops are configured to display the LCD screen when on battery power to allow longer operation on battery power. This can be overridden in the Control Panel -> Power Options but doing so will reduce the amount of time you will be able to work on battery power. The time before it enters sleep mode is generally shorter as well for the same reasons.
Apr 14, 2009 | Toshiba Satellite A135 Notebook
MY ACER LAPTOP SCREEN TURNS ON BUT THE SCREEN IS BLACK
To determine if you have a video card problem or the LCD screen is at fault.
Connect an external monitor to the video port on the laptop and boot up your laptop, if you get a display on the external monitor then your video card is OK and you have a faulty LCD.
When you power your laptop without an external monitor and have a close look at the LCD screen at and you see a slight image then the fault is with the backlighting panel. This fault could be a faulty inverter or a faulty CCFL backlight lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
The inverter can be easily replaced so can the CCFL lamp (but requires a lot more work)
For info on parts and repair service goto www.lcdparts.net
Mar 02, 2009 | Acer Aspire 5610-4648 Notebook
Hotpoint Ultima WF860 Front Load Washer Logo
1,326 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
