Photosmart 2575 cartridges leaking.
Photosmart 2575 colour cartridge and black cartridge emptyed their contents into base of printer over a period of 6 or 7 months, printer does`nt get used much .Is this a common problem? Its only the third time cartridges have been replaced. Thanks for any info.Darren...
    Problem Solver:
  • 13 Answers
Try to put your cartridge into hot water to make bubbles flow out from it... i have do it already... and it work...
Posted on Jul 27, 2009
    Guru:
  • 1,894 Answers
When not in use Store them in a cool, dry, dust free place and you should not have any problems
  • dewan nafees ahmed Jul 27, 2009
    do not insert the syringe needle more than about 10 mm into the cartridge chamber, while refilling.
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
Printer will not print blue, prints pink instead
Blue is made from magenta (pink) and cyan ( sky blue), if your blues are coming out pink then they are missing the cyan component.
In your machine this could be caused by a blockage in the printhead, the cyan cartridge being empty, an electronics fault, a boma pump fault (the squishy black thing on the base of the cartridge). Check your cartridge first - if it feels lighter than the other it is probably empty. Sometimes there is a fault where the entire contents of a cartridge (usually the cyan) can be emptied in a matter of days or less. If the cartridge is unusually empty compared to the other colours - refer it to HP.
Mar 13, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
Not printin g all the time & all blue
Without knowing the Model of Printer and any specifics I will try to cover all the bases I can.
If your printer uses a Tri-Colour cartridge and Black Cartridge then it is most likely that either the Magenta in the Tri-Colour cartridge is either Empty or Blocked or the Black cartridge is Empty.
To test this you can take the Tri-Colour and Black Cartridge out of the printer and press the Printhead against a tissue. The Black should be a solid black line approximately a centimeter long by 3 Millimeters wide. The Colour should have three solid lines, one of each colour Cyan, Magenta and Yellow. If either of these is not clear then the cartridge that does not leave clear footprints will either be empty or blocked.
If your HP printer uses seperate ink tanks for each colour then the Printhead may be blocked or the Ink Tanks are empty.
If it is a Laser Printer then there are several possibilities open. The Toner Cartridges are Empty or the Toner Seals have not been removed. If they are still full and the seals are removed then the Imaging Mirrors may be damaged or the Imaging Drum(s) may be damaged.
I hope that helps.
Jul 11, 2011 | HP Office Equipment & Supplies
Can you use 2 black cartridge instead of 1 black 1 colour in the HP all in one 2575 photosmart printer
You would not be able to.
The cartridge front is different and would not fit.
Also it is a requirement to have the correct cartridges to print.
Jan 11, 2011 | HP Photosmart 2575 All-In-One Printer,...
Hi Folks, Sorry to bother you but i have HP 2575 all in one for past 3 years,and until now had no problems..I recently changed my colour ink cartridge cos the old one indicating low toner and some colours...
Try to clean the cartridges by taking them out and trying aligning the cartridges again... try the alignment if you have any software named as image zone or solution center
Oct 21, 2010 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart 2575 printer - ink cartridge problem
Is this a Hp cartridge or a cheaper brand?
I got this error myself too with cheaper cartridges.
You cal solvo this error by buying the original Hp cartridges
Mar 21, 2010 | HP Photosmart 2575 All-In-One InkJet...
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
74 people viewed this question
jasbo
jasbo
