Gas fires up to heat water for 30 seconds then goes off
Gas ignites produces hot water for 30 seconds then goes off similar on cental heating
  • Bruce Hathcock May 11, 2010
    check for breaker problem first and since you are having problems with two items check your supply of fuel the shut off valve or a blockage of some kind do you have a tank or piped in gas from city? let me know and I will try to help you out.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Check the circulating pump is distributing the hot water, otherwise the heater will switch off because of overtemperature
Posted on Jul 28, 2009
Furnace wil, not ignite when calling for heat
For this answer, we need a model and serial number.
Generally, be sure the power is on, does the heat moving device run? (Fan for air, or pumps for water)
Nov 02, 2017 | Heating & Cooling
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
I have a Reddy heater 30-55,000 btu.. When lighting it I press in the initer for the recomended time but after I release it the flame goes out.. Can you tell me why?.
It seems as if you are not holding the igniter long enough after it fires, have you tried holding the igniter down for a few seconds more to allow the safety cut out to warm up, (Similar to the gas heaters, when ignited keep the flame going for the thermal coupling to heat up), If you do this and it still goes out the safety valve is faulty, but try holding it in longer before messing about with the coupling.
Jan 05, 2012 | Reddy Heater-30-55,000 BTU Variable
Pilot will light after 30 seconds when you try to move knob to on position the pilot goes out and heater won't ignite.
You need to replace the thermocouple.
When you light the pilot it is supose to heat the thermocouple.
the thermocouple produces a small electric current which allows the gas valve to open and keep the pilot going. and allowing the main burner to come on.
Jun 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
It does not fire at all times igniter works, I can hear the gas valve when opens, some times it fires for a minute and some times does not fire at all
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 07, 2010 | Heating & Cooling
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
My Whirlpool accubake is taking a very long time to heat up
It is possible that the igniter that lights the gas is getting weak... as they weaken it takes longer for them to heat up hot enough to ignite the gas. When you light the oven, you should be able to see the orange glow of the igniter within a few seconds (it's similar to a cigarette lighter from a car) within 20-30 seconds you should hear the gas light.
Sep 01, 2009 | Whirlpool Accubake RF362LXTT Electric...
Boiler wont work
you have a gas supply issue the baning is water hammer from the water heating
Jun 10, 2009 | Air Tools & Compressors
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
