posted by Aqdas on Nov 22, 2007
I have 6381-A3-302 router when it is switched on then ping shows request time out while LAN status light remains solid green.
I have also 6211-I1-300 which show request time out in ping while LAN status light blink normaly.
Best Solution
posted on Nov 23, 2007
according to your question, normally when a router is powered off, all the lights should go off, no light should blink in the router , and when you ping it will says request timed out, becos the is no connectivity in between the router and the computer and that is not a problem, it shows the correct response.., it the lan status blinks , the the is no proper connection, so do not worry, the proplem is if you get reuest timed outr message, when you router is on or else, when the wan light is steady,
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 16, 2008
i have paradyne paradyne 6381 a3 302 lost the driver cd. My new windows xp don't pick it automaticly. plz give me a slution.
Solution #3
posted on Jul 04, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
to reset all settings to defualt without having username and/or password check the back of router. there is a little button captioned as Reset Default. press that button.
Suggest a new solution for this problem
Post a New problem for Paradyne 6381 ADSL2+/ReachDSL Router
Email this problem
Email this problem
Can you Help with these Routers problems?
Paradyne 6381 ADSL2+/ReachDSL Router...
Reach DSL authentication...
We have come to a brick wall... Answer This...
Paradyne 6381-A3-200...
I have a 6381-A3-200... Answer This...
Using both USB and Ethernet...
hello, i have 2 pcs that i use... Answer This...
port fowarding
port fowarding
i have tried everything..even... Answer This...
PARADYNE 6381 DSL MODEM
I have a paradyne 6381 dsl... Answer This...
Repair Service
Find Router Repairman Near You:
