MONITOR NOT OPERATING
THE ON/OFF switch lights up and goes on and off and makes a clicking noise but no picture
  • 1 more comment
  • taffhassett Jul 27, 2009
    THANK YOU SWEET-RASCAL MY MODEL IS 19INCH digimate monitor L-1918 TFT/LCD 12VOLT
    THE MONITOR WILL SAY NOTHING AS ITS NOT ACTIVATING?
    to sweet-rascal 19inch DIGIMATE pc monitor L-1918 tft/lcd 12volt power regards ron
    Guru:
  • 1,894 Answers
I think the relay is ticking in your monitor. this is a problem in your power board. which happens due to some high volatge damaging the circuit.
if you tel me the model number and make it wil be helpful to give you a exact solution.
Posted on Jul 27, 2009
  • 724 Answers
Monitor an LCD needs the built in Power supply
CRT high voltage section died
    Scholar:
  • 85 Answers
Seems like its time for new monitor. To make sure that it is a problem with the monitor, disconnect the blue cord from the back of the computer. Monitor should say no signal or something similar. If not Go and get a TFT.
Sony Trinitron tv wont turn on no picture just makes clicking noise
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 09, 2014 | Televison & Video
Clicking noise
theres is a blown caoacitor in unit which will not allow a display
Feb 09, 2013 | Star Logic Monitor 11009515
When i boot up power button on monitor goes on off resulting in flickering picture.
hi look for a bulging or bad electrolytic capacitors in the PSU board which cause the output voltage drop, usually 1500 uf/ 16v.just replace those bad cap then it will resume to normal operation good luck thanks for consulting through fixya.
Jun 23, 2012 | Computers & Internet
My acer monitor displays the acer background, makes a noise like a buzzing sound and goes black, and then after all my settings and background picture and information are complete and up, the monitar...
It sounds like a backlight or inverter problem. You can verify this by using a bright light to shine on the screen surface. If you can see the picture (but it will be very dark) that means that the backlight which illuminates the screen from behind. You would have to replace the inverter to test it, but there is good news: These are pretty difficult to find parts for, and not an easy repair for an amateur; acer products usually have a 3 year warranty on the backlight/inverter system, so I would start there.
May 25, 2011 | Acer V193W 19 inch LCD Monitor
Monitor power light blinks, then goes out. PC screen goes black.
Unplugging the power cord repeatedly is not a good idea! I hope this helps: 1- After you get a picture, go to "Device manager" (Click on Start-Programs-settings-device manager) and make sure that there is not question or an exclamation mark next to Monitors. If that is the case you might need to reinstall the driver! 2- Make sure that your video card is not faulty by hooking up a different monitor and see if it is working ok. If you still have the same problem, then you need to replace the video card. 3- Check all cables and power cords and make sure that there's good connectivity on all ends (before powering up the machine) and that there are no nicks or cuts. If possible try replacing the monitor's data cable as well. Good luck
Apr 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Problem when turning monitor off
mcdevito75 here LCD, or liquid Crystal display, chances are the crackling is the inside liquid display trying to capture the in comming electricity to make a display picture. Remember even an LCD is nothing more than a light bulb, a very intricate light bulb but a light bulb, and you have light bulbs burn out when you put them on and almost never as the are on burning. Turning the monitor itself off won"t really save electricity or the monitor itself as, when you shut down the computer from Start (left side of screen) the monitors screen saver comes on for 10--20 minutes then goes off, at this point the electricity is at the monitors on/off switch and not going thru the monitor at all. If you turn the monitor off at it"s on/off switch, the sudden jump of electricity to the monitor from it"s on/off switch could hurt it, or even the switch. I have a friend who turns off the monitor also and that friend had a bad monitor in 3 years. I never turn my monitor off just the computer itself. I'd speak with a Radio Shack, Staples, Best Buy ETC. for more advise. Me I;d say leave the monitor on. Hope this helps.
Mar 27, 2007 | Samsung Syncmaster 730B 17" Flat Panel LCD...
EV 700
my gateway monitor makes a sqreeching noises when you turn it on. after that it starts making that noise like it does when its fixing to come on then it starts smelling like its burning then we turn it off. please help
Oct 18, 2006 | Gateway EV 700 17" CRT Monitor
Computers & Internet Logo
630 people viewed this question
David Payne
David Payne
