Question about Electronics - Others
No manual for 320 GB desk top hard drive
No manual for Iomega 320 GB usb 2.0 desk top hard drive. Do I just plug in usb and power cables and use like internal hard disk? I have windows vista premium
  • 390 Answers
Its a plug and play just connect to the sys and start working on it
but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
Posted on Jul 27, 2009
Computer doesnt recognize drive
Try a different usb port on the computer. Maybe the usb port you are using is bad.
Try the portable drive on another computer and see if it is recognized. If not, the portable drive might be defective.
May 29, 2012 | Prestige Portable 320gb Usb 20 IOMEGA ...
How do i wipe my iomega prestige 320gb hard drive
plug it into the computer when the drive shows up in my computer assuming your using windows right click on it and select format keep the default settings and hit ok to the format
May 11, 2011 | Iomega eGo Portable 320GB Helium 320 GB...
Have only just decided to install my new Iomega 500 GB usb 2.0 hard drive and I have mislaid my quick install guide. I have an Apple imac can you help please
Just connect the AC power to the IOMEGA, and the USB cable between the IOMEGA and a USB port on your computer. It is a "plug-and-play" device, and so Apple OS X should automatically recognize it.
Nov 21, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
I have tried connecting my Iomega 250 gb USB 2 Hard Drive to my computer and it is telling me that the unit has malfunctioned. Is there any way of getting the data off it?
First try connecting this USB drive to a different computer.
If this did not work then the USB adapter case is faulty, then remove the hard drive from the case and attach the hard drive to an USB hard drive adapter then plug it into a working computer's US port. If the hard drive is OK then the computer will see this as an external storage device and you can open the folders and files to backup the data off this hard drive.
If this does not work then there are companies that can recovery data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 21, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
Iomega 320 external hard drive computer wont recognise
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 15, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
I have an 320gig iomega external hard drive i can feel the drive running but the light is not comming on and it isnt registering on my lap top as been pluged in
You really need to provide more info. Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Mar 06, 2010 | Iomega Silver Series 320GB 3.5 External -...
Iomega 320 portable drive connection problem
sounds like a defective drive. maybe it took a bump in shipping?
take it back right away.
Sep 10, 2009 | Iomega (33576) 320 GB USB 2.0 Hard Drive
I have got a 500gb iomega hdd. I have got it plugged in to my laptop but my laptop will not reconise it. It has a blue power light flashing on the front. I have also tried it on the home desk top and its...
I had the same problem with this hard disk. I have installed paragon disk suite 2009. I ran the software and left it running after sometime it recognised my external hard disk automatically. Dont knw how it happened but worked for me.
Dec 19, 2008 | Iomega (33654) Limited Edition 500 GB USB...
Electronics - Others Logo
77 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
