Question about Philips ProScreen 4750 Impact Multimedia Projector
The projector does not operate the "lamp" led blinks in green and turn red after one minute. The switch on button does not replied.
    Genius:
  • 1,341 Answers
Either it's overheated or needs a replacement bulb.Do not cover this unit with anything as it will prevent cooling down..
Posted on Jul 27, 2009
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
Hi. I have a InFocus dp2000x. It has no lamp. I try with a flashlight in the lamp chamber (the flashlight is battery operated) When I turn on the projector with a vga or video input, the power led start...
Projectors are designed to be used with a lamp and will turn off when there isn't one present. You would have to purchase a new lamp to use the projector.
Feb 19, 2011 | ASK Proxima Proxima DP2000X Multimedia...
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Projector was turned off wrong and now wont turn back on.
if the led flashes once in 2-second intervals and you don't hear a high-pitched whir, the colorwheel needs replacing. if you do, the ballast is bad. if it flashes 2 times, the lamp is past 3000 hours. 4 times, fan error. 5 times, temp too high and it needs to cool.
Nov 07, 2009 | InFocus ScreenPlay 4805 Multimedia...
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
In the manual there is a chart which will indicate the nature of the failure depending on the number of times the red led flashes before a pause.
Most common is the projector's lamp timer has exceeded the operational lamp time limit.
While the projector's red led is flashing, press the volume up and down buttons on the projector simultaneously and hold them both in for 10 seconds.
This will reset the lamp inhibit protocol.
However if the lamp has thousands of hours of use you need to replace it before it actually fails.
Feb 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Philips ProScreen 4750 Impact Multimedia Projector Logo
245 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
