Question about Cpi (C1731) Burner
I don't know how to connect it to a wired local network
  • gerald134 Jul 28, 2009
    I was given an old Dell CPi A400XT laptop. It has a PCMIA card that says Ethernet but with a weird slit at the end - not something you can plug a netword cable into. I wondered how I can connect it to a wired network.
  • Douglessd
    Douglessd May 11, 2010
    Do you have a laptop you want to connect to a wired network? You may have posted this under a CD burner category by accident. Tell us some more about what you want to do and perhaps we will have some ideas.
  • 284 Answers
The weird **** would be where you connect an adaptor. Some people call them a "Dongle" The card you have would have came with one and if it is lost I would say you are stuck. The dongles are not interchangable between brands. You should be able to pick up another PCMCIA Ethernet adaptor on ebay for next to nothing these days. Modern laptops have their ethernet port built in. but a few years ago they were an add on cards so there are probably lots of old cards floating around. I know I have a couple in a draw at home :) Just make sure you can find drivers for the card that match your opperating system.
Posted on Jul 28, 2009
  • 746 Answers
Dear! I can help you to solve that matter. First of all you should know that how many computers do you want to connect? You have to use two types of cables 1. is cross and 2. is straight cable. Cross cable for same device to device and straight cable for device to nodes or computers. You can use proxy server and without any installation you can use DHCP server and connect PCs to eachothers.
Thanks
Posted on Jul 27, 2009
Installing OKI c3400n in Windows 7 32 bit
The c3400n does not have its own wireless capability. It must be connected to a wireless print server or to some wired network that has a wireless access point (WAP) connected to it. A third option is to use a home-networking wireless router.
Individual PCs must have wireless capability also, or they can't print over wireless.
Somewhere along the line the printer must get a local network IP address, i.e. 192.168.0.102. PCs usually use Dynamic Host Configuration Protocol (DHCP) to get an IP address.
But printers are usually manually set to a 'static' IP, because static IPs don't change over time.
Usually there is a security device called a 'firewall' to protect the wired network from unwanted wireless traffic.
So, you first require some form of wireless access.
The people who require wireless printing capability must have their computers configured to make an association to the WAP. Usually requires a passkey or password, depending on the wireless security method.
A port on the firewall must be forwarded to the port used by whichever network-printing protocol is being used to communicate with the printer. There are several possible protocols.
The printer must be set to an IP address unique within the private subnet, i.e. 192.168.0.0/16, used by the local network.
PC-based network-connected devices use IP (Internet Protocol) addressing, i.e. xyz.zxy.yzx.xzy
The printer must be connected to a network switch that is in some way accessible to the WAP. Residential/SOHO (Small Office Home Office) setups use a combination switch/router device, called simply: a router.
Most of the above is done automatically, but there are some set-up tasks that require user intervention. Electronic devices know how to configure everything, after they are given proper parameters.
All you need to do is check the above items. If the printer is found by MS Windows 'searching for network printers', the hard part is done. Then you just tell Windows to use the network printer.
Jul 22, 2012 | OKI C3400n Laser Printer
Can i connect new pc to old connection
You simply need to disconnect old computer from the network and connect the new one.
Are you trying to connect wired computer or wireless?
If you are trying to connect a wired computer then you don't need to do anything.
Just take out the Ethernet cable from the old computer and connect it to the new computer.
If you are connecting a wireless computer to the network then make sure that you have all the settings of your wireless router.
If your wireless network is secured then you should know the correct network key.
What is the operating system on your computer?
I will suggest you a website " The Router Setup " which may help you connect your new computer to the old wireless network.
May 17, 2012 | D-Link AirPlus DI-524 Wireless Router
Wireless is connected but internet wont detect connection
For wireless connections:
1. Hold the Windows key and press the R key, type services.msc and press Enter or click OK. This should open a new window - services local.
2. Look for Wireless Zero Configuration on the list in the right pane. The list is alphabetical, so you should be able to locate it maybe third from the bottom.
3. Double-click it to open it.
4. Click on the STOP button to stop it (lower left). If it is not highlighted or is grayed out, then the service is stopped. (it should also say that the SERVICE STATUS is stopped).
5. Look for STARTUP TYPE drop-down menu. Change it from AUTOMATIC to DISABLED. then click on APPLY (lower right).
6. Then just change it right back from disabled to automatic and click on apply again.
7. Click on START button (right beside the STOP button) on the same window to start the service.
--- We are essentially restarting the windows wireless service. What we did just turned it off and on again ---
8. Close the services local window.
9. Go to Start and then Control Panel. Network Connections. If you don't see Wireless Network Connections or Local Area Connection after opening Network Connections, kindly look for Network Connections again (it maybe on the lower right).
--- We need to be on the page where you have the wireless network connections icon. ---
11. Right-click on the icon for Wireless Network Connections then left-click on Properties.
12. You should have several tabs. Click on Wireless Network Connections tab (near the top of the window).
13. Make sure you have a checkmark on where it says, "Use windows to configure your wireless connections..." or something like that.
--- Before going into the next step. Kindly make sure first that you have the following CORRECT information: (1) your own SSID; (2) Network key (if you have one) - WEP or WPA or whichever encryption you are using. If you don't know these information, kindly secure these information first or better yet, try calling your router manufacturer to help you out on this ---
14. Then on the list that shows on the same window, remove everything on the list. That list shows all the wireless networks that you have been connected to before.
--- Don't worry about deleting it. The next time that you connect to the wireless network, it will be automatically added back into this list ---
15. Once everything is removed. Kindly close the window.
16. Go back to where you have the Wireless Network Connections icon again.
17. Right-click again the icon and left-click on View Wireless Network Connections.
18. If your wireless router is broadcasting your SSID, then you should be able to see it on the list of wireless network(s) that will appear on the screen.
19. Select your SSID and hit Connect.
20. It should be asking for your network key. Type it in. In might ask you to confirm the network key. Just type it in again.
21. It will attempt to connect it. And you will get a notification that you are connected.
22. Once you are connected, go back to the window where you have the Wireless Network Connections icon we were working on before.
23. That icon should say that it is connected.
24. Double-click it. It should open a new window.
25. You should have a General tab and a Support tab.
26. General tab should say it is connected.
27. Click on the Support tab.
28. Now confirm if your IP Address says 192.168.x.x. where x can represent any number. Example: 192.168.0.100
29. If you have these confirmed. Kindly try to see if you can now get into the internet or into your network.
30. Enjoy!
let me know if this don;t work for you Blankzero
Apr 15, 2012 | Computers & Internet
TI have a Dlink air plus g not sure what model it is but it is an adapter for a desktop pc, I moved to an appartment, and I can connect to a crappy unprotected motorola network but not the one that was set...
I believe the pick up signal for your internet connection should be wired, the D-Link device will create it's own local home network for you.
I don't think the D-link can connect to another network Wireless, only create it's own.
Do you need to connect to a wired or wireless 'appartement' network?
Sep 27, 2011 | D-Link AirPlus DI-614+ Wireless Router
Sir i lost my wireless network name and my wireless network password
to get back you wireless information,first you have to connect you laptop hard wired to the router using the ethernet cable, then open a browser and access the firmware of the router,usually for dlink routers,the default gateway to access the router is(10.0.0.1),but if you don't know the default gateway, you can go to the network connection by typing (ncpa.cpl) in the run box or the start search from the start menu. look for "LAN or Highspeed Internet or Local Area connection" then right click on it and select status. Note:make sure that the laptop is propperly connected via network cable.
you will have the "status" page.
for winXP: click on support tab and look for the "default gateway"
for win vista and win7: click on "details" button and look for "ipv4 default gateway"
The "default gateway" number including "dot" needs to be typed in the address bar of your browser.
The router then will ask you to enter the username and password,which is located in the back on side of the router. After you got to the router page, on the left pannel,click on "wireless settings" there you will see you wireless information.
Sep 22, 2011 | D-Link DIR-615 Wireless Router
I want to know how to connect my ssid pasphrase located on the back of my router and when i tried to conect it to my ps3 conole it said it was weak and it couldnt find the acess point or something so can...
i'm going to assume that you are asking "how to connect your ps3 to your home network?"
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
Turn on your ps3 and from the XMB...
1) go to Settings
2) Scroll down to Network Settings and press X
3) Scroll down to Internet Connection Setting and press X. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you wirelss access point for you home network and some other near your home along with few information such as....
...SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) ...SECURITY (this is the password you set up your network with) ...SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network probably wont do you any good since it'll probably be all locked with password and such. yours should also be locked and have password on it too.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password. Yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
Sep 01, 2011 | Sony Playstation 3 (PS3) Console
I can't figure out what ssid mean
Service Set Identifier....usually its used with a Laptop wireless router connection as a password you have to enter. I don't know if that's your applictation.
I had to enter one for my wireless Verizon DSL connection.
Jun 26, 2011 | Video Game Consoles & Games
After updating ubantu 10.10 maverick(?) desktop edition my internet connection (via wired connection aka eth0) has gone BUT i can still access my router (connected to cable modem) and all other machines on...
Try:
sudo route add default gw ROUTER.IP.ADDRESS
Replace ROUTER.IP.ADDRESS with the address of your network router. If you don't know what this is, do the following in Windows XP:
Start -> Run -> cmd.exe
ipconfig
(look for "Default Gateway", and write down the four numbers - usually something like 192.168.1.254 - that's what you should use for "ROUTER.IP.ADDRESS" above).
This will fix it for your current session - to make it permanent, open up the network configuration window in Ubuntu, and set this as your gateway under "IPv4 settings" (or similar).
Nov 16, 2010 | Canonical Ltd. Ubuntu
I have a wireless router, my vista laptop is upstairs in my room, my wireless network connection is working. but the "local area connection" says that there is a network cable unplugged. but i have...
"local area connection" is the wired connection, which in your case is "unplugged" If you go to control panel and look in connections, you will see that you are connected with the wireless, if you right click on the wireless there is a checkbox to display the status on your toolbar along side of the "Local Area Connection" Hope that clears it up a little
Aug 29, 2010 | Computers & Internet
Create a local area network
you can get a HP x175 printserver. (not expensive.) and connected it between the printer and the router. that way you don't have to have the desktop on all the time.
Dec 02, 2008 | Computers & Internet
Cpi (C1731) Burner Logo
80 people viewed this question
Top Cpi Computers & Internet Experts
David Payne
David Payne
Are you a Cpi Computer and Internet Expert? Answer questions, earn points and help others
