Question about Car Audio & Video
When playing CDs the CDs start jumping - Car Audio & Video
  • 53 Answers
Put a cleaning disk threw it could hav dirty lens
Posted on Jul 28, 2009
After jumping a dead battery (hot shot) the CD player died. It gave an error: it thinks that there are no cds inserted when in fact there are 5. It will not eject and I cannot insert. My hope is that I...
After my car battery went dead my cd player is stuck. It won't play, or eject and it thinks there are no cds in it when in fact it is full. HELP!
Oct 31, 2010 | Car Audio & Video
Yamaha CDC-765: sometimes skips when playing CDs
The problem is in the laser for sure. Try cleaning with a cd cleaning tool. It's the easiest solution because changing the laser is not always available solution.
Stelios.
Feb 21, 2010 | Yamaha CDC-765 5-Disc CD Changer
Code 3000ZAA3 shows on my CD player (JVC KD SC401) and it won't play CDs. Everything else works fine. Thanks!
You need to reset the CD player. Remove the front panel and you will see a tiny hole in the middle of the panel of the unit mounted in the dash (i.e. without front panel). Gently push a ball point pen or pin in to press the reset switch.
This should sort out the problem
Jan 10, 2010 | JVC Car Audio & Video
MY BOSS BV7970 DO NOT PLAY ANY BURN CDRW OR DVDS
Some players are picky with certain cdrw/dvdrw discs. You might have to experiment with different brands/types for your discs. I used to have a cd player (teac) which would just refuse certain brands cd-r discs but play others just fine. I know it sounds odd, but once I noticed which ones work and which ones don't I never looked back.
Also, have the "problematic" discs been recorded on just one recorder? Have you tried playing discs recorded on a different recorder?
Also - I'm sure you've already tried it-it's always a good idea to clean the laser just in case.
Hope this helps+
Good luck,
Raf
Nov 13, 2009 | Boss BV7970 CD Player
I have a Sony 400 CD that starts to play a CD but then skips and jumps back to restart the same CD over and over again. Do I need to replace the head or what?
if the same issue repeats itself in different CDs (with no major scratches on them), most probably either the head needs to be realigned or replaced.
Sep 01, 2009 | Audio Players & Recorders
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
Feb 18, 2009 | Televison & Video
Disc Jumping
I used to have the same problem: the rubber feet of the players are too stiff. It is indeed vibration that causes the problem. Btw: after a couple hours in a club, you are usually playing much louder than at home, with more low-end punch.
I haven't had a single problem AFTER systematically setting the players on foam. This is similar to the tennis balls trick for regular turntables, except that here you need something a softer suspension as the players are very light. Shipping foam is good; camping foam mattress works also.
Jul 14, 2008 | Vestax CDX-05 Turntable
Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
Car cd auto changer
IT SOUNDS LIKE A LASER PICKUP FAULT WHICH YOU WOULD NEED TO REPLACE, IF YOU ARE GOING TO REPLACE IT YOURSELF I SUGGEST YOU BUY A NEW LASER AND REMEMBER TO BE CAREFUL NOT TO DAMAGE IT WITH STATIC ELECTRICITY FROM YOU WHEN YOU HANDLE IT.
Nov 18, 2007 | Honda Auto Changer Board
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
