SOURCE: Screen resolution not available on Display menu
The 1920x1080 resolution has to have two things.
First, make sure you download the latest driver from Samsung Support site. I have the T240, and love the extra high resolution, but you have to have the driver installed.
Also, to get the resolution, your graphics card in the computer has to support the high resolution. You need to check the graphics card Mfg's website, and download and install the latest driver.
That should get you up and running, as long as the graphics card supports that high. Some of the older ones might not.
SOURCE: DVR won't set a timer to record a show
I have never encountered this but if you have enabled the standby and it still does not work you will need a new receiver. The feature was to enable a screen saver so that televisions screens would not be etched if it were left on and you fell asleep. My suspicion is that the DVR hard drive is corrupt giving you this false message.
Thanks for using Fix Ya.
SOURCE: sCREEN RESOLUTION RESET
When Setting The Screen Resolution There is a 30 second wait period where you have to click ok for the setting to take permanent effect. If you could not see anything it should have returned to normal within the time limit and or is not saved and can be returned to normal by reseting the computer via the power button.
Hope This Helps.
Sincerely,
Michael Scott
SOURCE: I forgot the password for my Defender Sentinel1
It can be reset only by the company and not others. Contact the care center to reset the password.
You may be lucky because the battery acid may not have gone beyond the contacts in the battery chamber: open battery chamber and clean out especially at the bottom of the chamber and blow out any loose stuff when you finished cleaning ( use pencil erazor or something similar , but do not use sand paper or anything that will damage chrome plating of the contacts ; you do not want corrosion at later stage ).
