Question about Garden
Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
I have the above Petrol Lawn Mower, I need a manual or service manual or Maintenance Manual for reference for the machine.
Also, if anyone has advise as I would like to service the machine myself so information on how to perform an oil change on this lawn mower sharpner the blades, and any other service needed on the lawn mower.
Currently my lawn mower stops running after about 10 minutes and will not restart.
Anything would be appreciated
Many Thanks
Karl
  • 1 more comment
  • Anonymous Mar 15, 2014
    free lawn mower manuals sanli 4 stoke lazer
  • Anonymous Mar 22, 2014
    annual service
  • Anonymous Mar 28, 2014
    LAWN MOWER
  • 3 Answers
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Posted on Apr 02, 2010
Testimonial: "Thanks very useful information.....Many Thanks"
Hi There
Did this problem get solved - I have a webb 300 Diplomat and it starts and runs fine for a couple of mins and cuts out and then like the other guys mower won't start for a while. Any advice would be great
Posted on May 09, 2015
It sounds like fuel starvation. Check that the fuel tank cap is vented
Paul@CuttingEdgeMowers.com
Posted on Feb 18, 2010
My problem is with a Webb H12R-A manual lawn mower which has the blade set on the lowest setting possible but doesnt cut the grass
Are the blades turning when you lower the deck? If not, your belt may be slipping or it's off the pulley. Once you lower the deck and lift your foot off the the brake / clutch it should engage because the slack is now taken up on the belt, so slipping, belt jumped off or belt stretched out.
Aug 30, 2016 | Garden
Manual for 909 118cc petrol lawnmower key start
Not enough info to even what is it.
A lot of walk behind mowers now have throttle-less engines. These engines run at a predetermined govern speed which the operator has no control over.
Jan 10, 2015 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
I changed the oil in my Craftsman Lawn Tractor 24HP Model No 917-288320 and the "change oil" message on the LED screen won't go away. Is there a reset button somewhere?
Below is excerpt from the owners manual:
SERVICE REMINDER/HOUR METER
Service reminder shows the total number
of hours the engine has run and flashes to
indicate that the engine or mower needs
servicing. When service is required, the
service reminder will flash for two hours.
To service engine and mower, see the
Maintenance section of this manual.
NOTE: Service reminder runs when the ignition
key is in any position but "STOP". For
accurate reading, be sure key remains in the
"STOP" position when engine is not running.
It should reset the 2 hours has expired
Jan 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When I start my lawn mower it will just stop after a minute or so I got about 5 minutes this morning it is very frustrating especially now my lawn is looking neglected please help
It sounds as if its running out of petrol,have you checked the tank for dirt,is your fuel mixture correct,or you may need a new carb kit,as if the diaphram is faulty it will cause this,rgds
Sep 26, 2010 | Garden
What would cause the lawn mower to stop running when not out of gas? If you give it a few seconds and restart it it will run again for awhile then stops. I have noticed if I pump the primer a couple of...
Try using non-ethanol gas. It's death on small engines. Starter fluid gives it a boost if higher octane. Have a reputable repair place clean out the gunk, then use good gas. Best of luck finding non-ethanol. Boating marinas carry it.
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have murray self propelled lawn mower. Last
Remove the air breather filter, it might be dirty. Stephen.
Sep 21, 2009 | Garden
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Garden Logo
1,904 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
