Question about Boating
Outboard motor overheating
I have a 1962 75 hp. evinrude outboad motor that keeps overheating.ive taken lower unit off to replace impeller,but impeller was in good shape.i connected a garden house right to the copper tube running up into engine and turned water on and then started motor.hardly any water comes out exhaust,and what little water that does comes out is steam and extremely hot.within 15 minutes,the overheat light on dash comes on.im stumped,it almost seems like something is plugging water jackets in motor.is this possible,or could it be something else? GARY
  • 677 Answers
Mate.The powerhead(engine block) is clogged.Don,t run it anymore untill its cleaned out or the motor will cook.Take the heads off 1st and see whats in the water jackets.It will probably be blocked.A build up of white 'gunk' is the main indicator.If thats the case,a complete cleanout is needed.Hope this helps
Posted on Jul 27, 2009
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
Coleman outboard overheating
You should change your impeller.
It is located at the top of the gearbox, around the vertical engine shaft.
First, disconnect the gear control. Underneath the steering bracket, you'll see a long nut with a counternut. ( Maybe you'll have to shift FWD or BWD to get better access ). Loosen the counternut 1/4 turn and then turn the long nut up ( 2 open box wrenches 10mm ).
Then remove the 4 bolts holding from lower to upper the gearcase ( just above the anti-cavitation plate )
The gearbox should drop down easily.
Then remove the 4 screws of the waterpump ( top of gearcase, around the long vertical shaft ). Lift the waterpupp housing, you'll get the impeller.
To reassemble the waterpump, grease the cup in the housing with PTFE or silicone grease, and while pushing the housing down over the impeller, rotate the shaft clockwise.
Reassemble all the rest in reverse order.
Check and adjust the gear shifting...
Apr 01, 2014 | Coleman 9.9 HP Manual Start Outboard Motor...
I have a evinrude 28hp outboard which is not pumping water. drive shaft seems in place and impeller in good nick. have put hose at bottom of inlet pipe and water runs through motor and out outlet. water...
Check pump housing and plate for wear,make sure aluminium housing not corroded under plate. Suggest fitting electric drill to drive shaft and emerse lower unit in bucket of water.make sure drill doesn't get wet.is motor going into gear,maybe splines are rusted off in crankshaft,could also have holes in inner exhaust side plate
Sep 04, 2013 | Sierra International 18-4310 Marine...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
1997 Evinrude 50 HP SPL. I have removed all the bolts holding the lower rnd to the engine, it seems to be hanging up on the shify shaft, and I can't find a way to drop the unit. It drops down about...
Okay this is on total memory. The shift shaft for a lot of those engines goes right up through the pilot shaft and exits just in front of the block under the carburetor(s). You will see the **** linkage arm connected to this shaft sometimes it's double nutted. See if you can slide the lower unit back up to the housing and put a bolt in it to hold then undue the shift shaft linkage, Remove the bolt and drop the lower unit. Be careful of the water tubes and check make sure the rubber grommets are in place in the pump housing not on the tubes. Clean up the pump housing and install the new impeller kit.
Put the impeller down the shaft on top of the impeller plate, lightly grease the inside of the housing the impeller plate and impeller. Then lower the pump housing down to the impeller while turning the drive shaft clockwise lightly push down on the impeller housing. This will fold the impeller blades all in the correct position and provide lubrication to the pump until the water gets into the pump. To make life easier re-grease the drive shaft spline and the water tube grommets this will ad ease in reinstalling the lower unit. be careful to make sure you thread the drive shaft, water tubes and shift shaft all in at the same time. After installation you may find you need to adjust the **** linkage.
Dec 11, 2010 | Boating
How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Apr 24, 2010 | Boating
Boating Logo
959 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
