Question about NEC Dterm DTP-2DT-1 Phone
Deactivating Do Not Disturb command
How can i Deactive Do Not Disturb command?
I loosely followed Solution #2's answer. If you pick up the phone, the display screen will show options above each of the 4 'arrow' buttons. The one to the far right, for me anyway, showed something looking like this: >>>
I hit it and it showed a number of options, one being "DND". Hitting that deactivated (or activated) DND on the phone I was currently on. That solved the problem for me.
Posted on Dec 07, 2009
Try this:
"Speaker" "7 4 7"
or
"Feature" "6 9" "Feature"
Posted on Sep 23, 2009
  • danzavier Feb 18, 2011
    feature>69>feature worked for me!! thanks!
  • 88 Answers
GO to network setting and go to active call diverts, you should find some options select what you want which isnt do not disturb.
Remember its not the same on all phones, but to solve this you must still find (active call diverts) somewhere on the phone.
Posted on Jul 27, 2009
I tried both and they didnt work i have a dterm series e phone, any other suggestions
Posted on Dec 22, 2009
I need to login to my account so that i can deactivise my phone
you can do that by logging in to your apple id - appleid.apple.com, login using the credentials and check for deactivating your account.
Jan 16, 2015 | Apple iPhone 6
What are the precautions to take when removing the battery that will not disturb the car radio when you have no resetting disk for a car radio
get a 9 volt battery and cigarette lighter plug and connect the 9 volts battery positive to the center wire in the cigarette plug and negative to the second wire, then plug it into your cigarette lighter socket, then you can remove the car battery and install the new car battery. good luck :)
Oct 14, 2014 | 2005 Ford Fiesta 1.3
How do i take of Do Not Disturb on a Meridian Norstar M7208
Feature #85
The # command is used to undo some commands.
Carl
Aug 12, 2011 | Lands Phones
I have a 2005 JGC 5.7 hemi and sometimes remotes wont work only when you want to unlock it.If you use the key to open door alarm sounds. what could be the problem?
Have you tried a new battery in the remote, or do you have a second remote you can test. Either your remote is worn out or the battery is dead.
Once you lock the car with your remote it will active the alarm and if you use your key it won't deactive the alarm only your remote will, on some cars putting the key in the ignition will deactive it.
If you can deactive your alarm with your remote and can just manualy lock and unlock your doors and that should prevent your alarm from going off until you get a new remote or battery.
Aug 05, 2011 | 2005 Jeep Grand Cherokee
My blue tooth is on i need to turn off to use usb lead but screen is broken
Top three suspects
1. Take your cell to a local phone shop to have the screen replaced 2. Without being able to see the screen because its broken, deactivating wifi bluetooth is next to impossible 3. Try to remove your battery to reset the cell system, this may deactive the bluetooth
Jan 31, 2011 | Samsung Cell Phones
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
May 10, 2010 | Lands Phones
Would like to unsubscribe facebook
You can deactive your account by going to Facebook, then click on Settings and then click on Deactive account.
Feb 01, 2010 | Computers & Internet
How to deactive GPRS in telenor..
dear,
if you have to pay for it to telenor then u have to ask to your service provider to deactive it but if you are not paying for it then just delete the settings in "gprs setting" that have been sent by telenor to you.
koi bhi service provider aap ko setting bhejta hai tu woh messages ki form mein aati hai or setting mein ja kar fix ho jati hai.. ab mujhe nahi pata k telenor ko pay krna parta hai ya nhi...yani paisey us waqt to kattey hi hain laikin agar telenor ne koi package diya hai to subsription k waqt bhi kattey honge.. aap deikh lo aapko do options di hain.
goodluck...
Sep 03, 2009 | O2 Samsung SGH-E250 Cellular Phone
I cannot deactive silent mode of my samsung e250
hold in your # key,it will de-activate silent mode. its a toggle switch.
Jul 17, 2009 | O2 Samsung SGH-E250 Cellular Phone
Zero Rings during meetings
With either a Do Not Disturb (DND) or Call Forward all calls command. On a TA-824, DND is set up with the command 714# on the intercom. It will light the DND button. It's cleared with 710#. There is no function to the button, ie you can't push it on and off. If you have voice mail, you can set it to forward all calls via the 711 (vm ext) #. It will blink the FWD/DND button.
As an aside, 7341# stops paging to the phone. 7340# brings it back. Again, these are TA-824 commands.
Carl
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
1,200 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
