Question about Car Audio & Video
No sound but all digit indication OK CLK 350, 2007, 13,000
2007 CLK 350 14,000 MILES THE RADIO ALL WORKS WHEN USING MUTE THE INDICATION IS OK, BUT NO SOUND IN ALL MODES RADIO, CD OTHER NO SOUNDS.THE DIGITAL DISPLAY ON THE RADIO AND ON THE DASH IS ALL OK AND SHOWS CHANGES. IS IT POSSIBLE THE BRAKER IS OUT OR THE AMPIFIER IS OFF. IS THERE A RESET EASY TO REACH ?
  • 97 Answers
It could be that the fuse is blown for your speakers
Posted on Jul 28, 2009
Need Help
I think you've answered your own question, circuit power is not going from one side of the DSP chip to the other and that suggests that the DSP's core is at-least partly DOA. You are indeed correct that functional power should be at 3.3V and yes 0.3V does make a difference to the components that rely on a 3.3V feed, however if the DSP is fried you are not going to see normal functionality or be able to diagnose further.
Sep 04, 2007 | Audio Players & Recorders
When i put the fm radio it display auto muting and doesnt have sound, this only happens with the radio because the dvd sounds ok
"Auto Muting" in the context of FM means the output will be muted if the signal is so weak it would result in mostly noise anyway. Interstation radio noise can be annoying and dangerous at high volumes.
Aug 14, 2011 | JVC TH-M303 System
Clk 2000 compressor year 2000 . 100500 miles. Key opens car,Interior light comes on, but will not turn in ignition at all. was ok yesterday. ? Regards Barry Kendall Rockester Kent
First check the power of the battery, it still has a small amount of power to light up any lights but using it to crank the engine requires a lot of current or power.
Better charge the battery first, if you consider to the/pull down the battery, turn on the radio and get the pin code first it will be erase when you remove the battery.
Hope that helps you out!
Aug 07, 2011 | 2004 Mercedes-Benz CLK-Class
Sound quit coming from speakers. Radio fuse OK. All lights work on radio. Any ideas. Also, how is the radio removed?
depends on how new the radio is, mine is fairly new and has a wire for "call mute" out of the back. its an optional wire i never used, this wire must have wire tape or something on it to keep it from grounding out. if it does, it will mute the radio like its supposed to. to remove the radio you'll need a set of these http://www.roverparts.com/Parts/LRA_76_001ABP.cfm you can find them at almost any auto parts store
Aug 11, 2010 | Ford Ranger Cars & Trucks
My stereo says 'muted' and does not work except when in reverse
They have a speed dependent volume so it does have wheel speed sensor input which could cause the wierd reverse only operation. It sounds like a software problem-I would try version coding the head unit(which will have to be done if you have a c.d. player or telephone in the car. Try to unmute it from the steering wheel buttons it may think there is a phone in the car and is muting the radio for phone operation. Your best bet is to pull codes and version code with a s.d.s. machine or at least a hand held tester but the majority of after market scan tools will not communicate with the d2b system which is your radio or sound system. good luck I hope I have been helpful
Sep 16, 2009 | 2000 Mercedes-Benz CL-Class
My radio is muted and will not unmute . how do i ummute my radio in my 2005 clk 500 mercedes
LOOK IN GLOVE COMPARTMENT.FOR THE OWNERS MANUAL.IT WILL TELL YOU HOW TO PROGRAM OR REPROGRAM YOUR RADIO.IF YOU DONT HAVE A OWNERS MANUAL.YOU WILL HAVE TO GO TO THE MERCEDES BENZ DEALERSHIP.THEY PROBABLY CAN PROGRAM IT SO YOU WILL HAVE SOUND.ALSO CHECK FOR A MUTE BUTTON.ON RADIO PRESS IT .YOU COULD ACCIDENTALLY HIT THE MUTE BUTTON AND SILENT RADIO.IF MUTE BUTTON DONT HELP.ITS PROBABLY A DEALERS FIX.I TELL YOU BACK IN 60S 70S 80S YOU COULD GO TO RADIO SHACK BUY PIONEER AND ALPINE RADIO PUT IT IN YOUR CAR.TURN IT ON.DIDNT HAVE TO PROGRAM CODE IT. LIKE THESE NEW RADIO SYSTEM.
Aug 29, 2009 | 2005 Mercedes-Benz Cl-Class
1999 Mercedes CLK radio antenna
look at antenna wires make sure every thing is in contact.if all is good.sound like problems in the sound amplifier.in radio.
May 06, 2009 | 1999 Mercedes-Benz CLK
Changing time on clock radio 1999 ford explorer xls
To set the hour, press and hold the CLK control and press SEEK. (Use arrows to increase or decrease hours). To set the minutes, press and hold the CLK control and press TUNE and use arrows.
This should work unless your vehicle has a separate clock module.(Other than the digital radio display).
Mar 01, 2009 | 1999 Ford Explorer
Need to set the clock
press CLK button to temporily display clock to set clock press clk > 2 sec use the left and right arrow to set hour and min
Aug 22, 2007 | Jensen KDC-9520 CD / Cassette Player
Car Audio & Video Logo
257 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
