SOURCE: water tank is suddenly filling up
look closely how the water flows from the evaporator to the tank. does it goes first to the condenser ?..or is there a heating pipe that is touching the tank in order to heat the water for it to evaporate?
here's the set up, your ac would cool and absorb moisture in the air and becomes water in the evaporator. these water is sometimes used to cool the compressor or the condenser to help it run cooler and at the same time evaporates the un-needed water . but incase the water is so much then you have the tank to keep the water from spilling. sometimes they still put some hot pipes to further heat the water to evaporate.
check those pointers that i have mention.
in some case, the air in your place just got humid and wet that is why it has too many water condensation..
SOURCE: my steamvac leaks from the clean water tank
you have either a cracked housing, or a valve is stuck open. if you can spray a small amount of wd49 into the valve, and work it a little, youmay be able to dislodge whateverdeposits have built up in there.
SOURCE: Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with
pliers. Also, make sure the dehumidifier is up a lot higher than where
you're draining it into. Mine drains into a utility sink. But I have
the dehumidifier propped up onto a dresser. I cut a small piece of
hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
SOURCE: Getting ''Fill Water'' message even though Tank is full
Gently remove tank the slide it back in place make sure the back of tank makes good contact with the machine when it is being lowered so that the reed switch can read the magnet in the tank.
