Question about Nintendo Action Replay DS for DS and NDS Lite
All gone It was working perfectly when one day i put it in and then took it out put in game and froze and did colorful lines(not red and blue yellow and something). i turned it off tried again and it said it had 0 codes or games on it.
I had the same problem with mine and all u can do is bye a new 1 ssry buddy
Posted on Aug 08, 2009
Plugs have not been touched. But now - NO COLOR! Yellow (video) is in top plug (blue socket) white is in white socket, and red is in red socket.
you need to put yellow in yellow and red in red and white in white........YELLOW not to blue is to yellow
Let me know if this help
Jan 15, 2011 | Nintendo Wii Console
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Replacing the thermostat, took the old one off without marking the wires. Hooked it up by color and we get the furnace when we put it on cool. wires are green, red, yellow & blue (ground wire)on the...
the normal wiring for stats is white=w=heat,red=r=24volts,green=g=fan,blue=c=common,yellow=y=cooling.
see what ties into your furnace board and match the terminals.
Aug 12, 2008 | Honeywell Heating & Cooling
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEARED ON MY SCREEN???
hey, i had the same problem and i fixed it. i took the battery out and saw the 4 golden tabs behind the battery. there was two tabs that u could pull out. i lightly pulled them out a little bit. the problem was that the tabs wouldnt hit the battery to charge it. thats why it put the tri colored screen on the front. also my charger fit into the charging hole in the phone, but it had to be moved around to much that it did not fit exactly. I have been rough with the charger so it moved the inside of my phone around. i put the charger in the phone and moved it around gently around untill the light lit up on the front at the top by the word at&t. after it was completly charged, i turned it on and it worked perfectly. i hope this helps in whoever may have this problem because i know it sucks!
Thanks
Aug 08, 2008 | HTC TYTN GSM Phone
Action Replay DS
All you need to do is, when you have those blue and red lines, means the codes are corrupted. To fix this, you will have to reset the Action Replay. To do that, you need to do this:
1. Hold down the A and B buttons before turning the console on.
2. Turn the Ds on while still holding the A and B, but when the health and safety screen comes up, hold down Start and Select too, so you now have 4 buttons held down.
3. Keep holding all 4 down until the main screen of the Action Replay appears. You'll have no games, which is no worry now because you can hook it up to the computer and update your AR with all the games again.
Hope this helps!
Mar 01, 2008 | Nintendo DS Lite Console
Nintendo Action Replay DS for  DS and NDS Lite Logo
336 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
