Question about Blaupunkt Car Audio & Video
Peugeot Blaupunkt 5 CD changer Flashing lights
The Blaupunkt 5 CD changer on my Peugeot 307 does not work. The light on the right keep flashing. I cant get the CDs out. had to pull them out with tweezers. Pleasehelp!
SOURCE: Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Posted on Jan 23, 2008
Eagleeyes
  • 199 Answers
SOURCE: cd player
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Posted on Feb 24, 2008
Eagleeyes
  • 199 Answers
SOURCE: 307 5 disc cd changer wont play or eject cd,s 2003 307.
hi there is a repair kit for this unit.
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html
mark
Posted on Jul 21, 2008
SOURCE: peugeot 307 04 plate
just disconect leads on cd changer should reset
Posted on Dec 19, 2008
SOURCE: 5 cd changer on a
same problem. car center says it's the lens that doesn''t read the cd's good anymore ?
Posted on Jan 26, 2010
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 BP905038637756 7607769050, code please?
PEUGEOT Blaupunkt
There may be 2 different codes depending on how old the car /radio  is.
Try 3963
and if your radio will not accept any digits higher than 6 ( ie 6666 is the highest  )
then try 2211
Sep 04, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307
having same problem. faulty after disconection of battery
Jun 03, 2009 | Blaupunkt Car Audio & Video
Flashing lights on cd changer, Peugeot 307!
There are a few variations of this model eg; IDCA09,IDCA04,Fiat & aftermarket units.As already stated these models do suffer from mechanism faults quite a lot.This is due mostly to the complexity of the mechanics.The flashing lights are a classic symptom of a jammed or broken part of the mechanism.They can however be repaired by certain car audio repair centres here in the UK.I'm afraid unless you know what you're doing then just by stripping the mechanism down is unlikely to cure the faults than can occur.
Feb 03, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
5 cd changer on a peugeot 307 has all 5 lights flash but will not play
cd changer off set common fault had it happen three times due to buttons being pressed to quick take changer out remove leads for a minute replace them turn on ignition should reset if not cd drive wiil need to be relined see dealer repaired one but really tricki
Dec 14, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
hi does it do anythig at all? does it flash?
Mark
Mar 21, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Jan 09, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
427 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
