Question about NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter
Netgear wn111v2 wireless network adapter
The cd i have from it wont install the software properly, gets to near the end of install and something about windows visual c+++ 2005 comes up and it says unable to install please try at another time.
However it still allows me to search for wireless internet clicking the button next to the clock in bottom right of screen. My network comes up fine and is usually 3/4 bars out of 5, i click to join the network and enter my password, occasionally it will let me join for 30 seconds then disconnect and other times it will not let me join at all, when it rarely connects for the 30 seconds the internet speed is slow. I have 50mb internet with virgin media and a netgear wireless router which i know works fine because i am able to use the laptop anywhere around the house with no problem.
I am using the network adapter on my desktop and really need it to work so i can get on with some work.
I wasnt sure if the issue is because i couldnt install the software for the network adapter and i dont know if its inteference(theres an immersion heater in the way). If there is inteference would 3/4 bars out of 5 always come up when searching for networks? My pc is a dell i bought about fortnight ago and runs on windows vista
  • 1,272 Answers
The installation issue is not related to interfrence. Could you please let me know if you have installe the adapter using the drivers from the CD or from the NETGEAR website?
This will helps us resolve the issue at the earliest.
Posted on Jul 27, 2009
Netgear WN111v2 Adapter disconnected
Is the Netgear Wi-Fi Management software installed on the computer? If it is, you may have a conflict between Window's built in Wi-Fi Manager and the Netgear Wi-Fi Manager. If it isn't, you may need to install it.
Assuming it isn't, there's links to download the software at the Netgear Global Download Center.
I would default to the most current version, if you're running Windows XP, you may need to install the v2.1, however, I would assume the v3.1 would be backward compatible with XP.
Install the software and follow the prompts that will guide you through the installation/setup.
Now, if the software is already installed, you need to find the program and configure it through that avenue. If that does not fix the issue, you should uninstall the Netgear software, remove the Wi-Fi adapter and reboot the computer. After it completely boots back up, you should either plug in the Wi-Fi adapter, let Windows recognize it and install the drivers, (they should still be in the system even after you uninstalled the software). Once Windows successfully locates and installs the drivers, reboot the computer again, (no need to remove the adapter). Once Windows completely loads again, open Start, Control Panel, and System. On the resulting window, click the hardware tab at the top then click the "Hardware Manager" button in the middle about 1/3 down the window. Click the "+" next to "Network Adapters" and verify that your WN111v2 is indeed installed.
Assuming it is at this point, close out everything but the Control Panel and open "Network Connections". Find the wireless adapter there, (may be listed as "wireless connection2" depending on how many times it's been installed). Right click on the wireless device and select "Show Available Wireless Networks"
I'm also uploading a video showing what needs to be done.
Establishing WiFi Access in WinXP
Jan 27, 2014 | NetGear Computers & Internet
I am currently running internet on a NetGear wireless WG111V3 adapter and I am trying to install the NetGear wireless WN111V2. As far as I know I have all of the correct drivers and also updated Windows...
1 Download using the button below to a convenient place such as your desktop.
NOTE: After downloading, DO NOT RUN THE FILE YET. Please proceed to Step 2.
Download Link
2. To properly install adapter software, please remove drivers that were previously installed.
To uninstall, go to Start > Programs > NETGEAR WN111v2 adapter > Uninstall NETGEAR WN111v2 adapter or through ADD/Remove program
3. Unplug the WN111v2 adapter from your computer.
4. Run the file you just downloaded and follow the on-screen install instructions.
Mar 01, 2011 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
I've installed the NETGEAR WN111v2 - It says that it have connected to the internet. but i yet no internet is found.
Open your run option on the start menu, type in msconfig, run it. go to the startup tab. uncheck the box next to Netgear WN111v2 Smart Wizard.
Next go to the start menu, My Computer. Double click Local Disk (C:), double click Program Files, double click Atheros, double click ACU (atheros client utility). Select Options from the main menu bar. Select "Select Client Software". Choose Windows. Hit OK. Close atheros and you should be in business.
Oct 09, 2010 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
My adapter wireless N WN111v2 is not found
When I insert the adapter WIRELESS N WN111v2 during installation, a message said me : your adapter wirreless is not found !! Help me please
May 08, 2010 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
I don't have the cd for the wn111v2, when i plug in it won't detect hardware, i now the device works, i plugged into my computer and work and it started right up.
If you are facing trouble with the installation of the adapter WN111v2 then please visit the below link to download the drivers:
WN111v2
Install the adapter using these drivers and configure the wireless connection.
Hope this helps.
Regards
Anand
Mar 25, 2010 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
I have a netgear wn111v2 adapter. I tried installin the software which i downloaded from the the netgear site....when i doubleclick the smart wizard...the window flashes and disappears...I'm using a...
1. Try deleting Cookies, Temp Files and restart computer
2. Download the files again and try installing it.
3. Still Same Issue, try different browser.
4. Still no Luck, Restart computer in safe mode with networking and download the software again.
Good Luck
Mar 10, 2010 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Why is the transfer rate of wn111v2 only about 1% of max?
Perhaps it has to do with the speed of the Network Connection?
Nov 28, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
I have a wn111v2 with no install cd my home com has no internet how do i get a install cd so i can use it
go to the netgear driver and support website, enter your model number and you can download the software from there
Nov 16, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Netgear WN111v2 software won't install
Hi, Visit the link below to download the latest drivers for the adapter:
http://kb.netgear.com/app/answers/detail/a_id/7528
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 27, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter Logo
617 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
