Question about Apple iPod nano 2nd Generation MP3 Player
My ipod won't open.
I tried holding the center and menu button for 6 seconds, but nothing happen. what should be the problem?
    Problem Solver:
  • 13 Answers
Maybe it has a virus on it..
Posted on Jul 27, 2009
When i plug in my ipod classic it doesn't show up in my itunes. i have tried restoring my ipod then putting music back on it. it says it has synced all my music but then i eject it and there is nothing on...
FIRST DO THIS- With iPod unplugged!
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select(center button) buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button (center button) is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Then try this-
~with iPod disconnected
~In iTunes make a new 'Playlist'
~add all music you want to the list
~connect your iPod
~drop n drag that Playlist to your iPod C.
~disconnect iPod, it should now show your music.
Mar 22, 2011 | Audio Players & Recorders
I have a 4gb ipod blue screen hour glass...nothing else.
Have you actually been holding down all buttons? If so you will want to reset the ipod. Just in case you are unsure as to how to reset the ipod I have posted a step by step below. Hope it helps you :)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer.
Apr 25, 2009 | Apple iPod nano
My ipod chromatic is completly frozen.
You are doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 07, 2009 | Apple iPod nano MP3 Player
Turns on but wont play my music
Your center button my be broken. Try reseting it (hold Menu and the center button for 5 seconds) or restoring it in iTunes.
Mar 14, 2009 | Apple iPod nano
Help
Hi, Try this out...
1) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 28, 2009 | Apple iPod nano
Turning off IPOD 1059
If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Feb 22, 2009 | Apple iPod MP3 Player
My ipod nano wont do anything
Hope this helps
Jul 19, 2008 | Apple iPod nano 3rd Generation
Ipod 30gb black
hold the menu and center button for 25 seconds.
That will reboot it without damaging your data.
Jun 26, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod Nano Won't come On!!!
make sure the hold is off and hold the menu and center button for at least 6 seconds and it should work
Jan 17, 2008 | Apple iPod nano
umm im not sure if this will work but you could try holding menu center button untill the apple comes up (this may not work if ipod has not got any power to run)
Feb 22, 2007 | Apple iPod nano
Apple iPod nano 2nd Generation MP3 Player Logo
51 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
