Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Won't Turn on
My thomson scenium 52" won't turn on Via remote control
Colours were OK before fault.
What would i need to replace?
How to unlock child lock without open tv
Posted on Jul 20, 2012
  • 167 Answers
Check the batteries in the remote 1st. If that don't work, call a TV tech to replace the IR sensor in the TV
Posted on Jul 29, 2009
I need thomson scenium 32wf64 s remote code for a universal remote (the remote only does 3 digit codes)
Your universal remote probably has a code search feature which you can use to find a code that will apply to your Thomson TV. If a search through all codes stored in the remote fails to work, you may have to try another universal remote.
Jan 03, 2015 | Thomson Televison & Video
TV Thomson Scenium 28WF64E L
See that any of the buttons are pressed or any thing is shorting any of the switches or wires or PCB in your Television
Mar 15, 2008 | Thomson 28VK25US TV
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Ambient remote control 5884 won't turn fireplace on and off
  • Make sure your valve is in the "on" position and not "pilot".
  • Install fresh batteries in both remote and receiver (remotes are finicky about good batteries.
  • Ensure the switch on your receiver is in the "remote" position.
  • Follow manual to re-sync handheld to receiver if necessary.
  • A burner not lighting could also be the fault of the appliance (bad thermopile). Check this too, and replace if needed.
  • Replace remote if necessary: Universal Fireplace Remotes
Dec 28, 2012 | Ambient Tech. Rcmt Manual Fireplace Remote...
I have a Thomson Scenium 67" and just turn off by
Can you please send me the model number. I will be better able to assist you. And another more detailed description.
Dec 15, 2011 | Thomson Televison & Video
My 32" won't turn on
Hello
Without its remote control, you can't unlock this TV. Get into this link from where you can buy it.
www.emtcompany.com/sylvania-srt2232s-remote/rc64.html
The price quoted is $19.95 [Shipping free]
OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
It wont turn on its stuck on stand by any suggestions? when we do get the tv turned on we cant knock it off or it takes hours of fiddling with the remote standby button to get it back on the tv is a...
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Let me know if you need more help or info.
Nov 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
Feb 11, 2009 | Thomson LCDB 03B 27 in. Television
THOMSON SCENIUM 44RW65US Red light flickers
i have the same problem. i have to switch it off at the mains 5 times b4 it comes on
Feb 08, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
338 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
