Question about Pentax Optio M60 Digital Camera
Pentax M60 My problem with my camera is that she turns on and off when I apen it, what cand I do?
  • 724 Answers
You need to put new lead in your pencil she needs to have the batteries charged at full capassaty
Posted on Jul 27, 2009
Pentax optio m60 card locked
Your memory card is in the locked mode. The SD(HC) card has a little switch to the left side, when you look on the factory logo off the card. It should be in the up position. When down (locj position) it is write protected. (You also can't format the card)
Be sure you do the format in your camera. When formating in your PC, it could be the camera can't read or write it.
Nov 10, 2013 | Pentax Optio M60 Digital Camera
Would olympus software work with a pentax camera
It depends on what you want the software to do with the camera. If you simply want to download the pictures then any photo cataloging program such as Picasa will do the job.
If you want to edit your photos, photo editing programs don't care where the photos came from. You can use any photo editing program, such as PhotoShop or the GIMP.
Jun 20, 2012 | Pentax Optio M60 Digital Camera
When the Pentax USB cable is connected to the computer USB outlet pictures do not appear on computer
make sure camera is in the play mode and powered on. If this does not work, sub out the cable to make sure it is not the cable. The last thing is to reinstall the usb ports - this is almost never necessary - but to do this start/control panel/system/device mgr, find usb root hub and right click uninstall to each. reboot and they will reinstall automatically.
good luck
Jun 16, 2011 | Pentax Optio M60 Digital Camera
My Pentax Optio M60 have problem with display. When you turn on the camera the display is fully black so you cannot see the object what you want to pictured. Servis man say that motherbord is dead and it...
The service man you talked to is correct. It will cost more than the camera is worth to get it fixed, if you can find someone to fix it at all. Cameras are available now with much better specifications than a year ago, at lower prices than ever. It makes no sense to pay a lot for a repair and end up with an old inferior camera at the end of it.
Dec 02, 2010 | Pentax Optio M60 Digital Camera
Internal Memory on Camera wont allow format
You usually have to take out the SD card, close the door and then delete images in camera in the normal way (press delete button in play mode, when confirmation dialogue appears, press delete button again, select >delete all< and press OK). Most cameras default to the memory card when one is inserted, that's why you have to take it out to delete data from the internal memory.
Hope that helps
Aug 01, 2010 | Pentax Optio M60 Digital Camera
I have a pentex optio m60 it was okey but suddenly it saying battery depleted could me please tell me what is the solution for that and why does it happen
There could be a couple reasons for this:
1. When you have the battery in the charger, does it indicate that the battery is dead or fully charged. I would suggest placing the battery in a universal charger to check to see what the rating is on the battery, a universal charger will indicate the true power left. If the universal charger shows the battery is drained but your charger says it's full, you have a bad charger. If they both indicate full but camera says dead, you have either a power supply issue in the camera or the main board cannot read how much life is actually left in the battery. If your charger says full and the universal says empty, your battery is malfunctioning.
2. Does the camera turn off when it says battery depleted or does it simply keep telling that it's depleted. If the unit doesn't shut off, you have a firmware issue that needs technical repair on. That specific model does not allow you to download updates via USB from your computer, you need to send it to Pentax for repair.
Dec 08, 2009 | Pentax Optio M60 Digital Camera
Pentax m60 black PROBLEMO
Please dont experimet with it and take it to service center and replace it
Sep 02, 2009 | Pentax Optio M60 Digital Camera
I find the schematic diagram for Pentax Optio M60
I think to look for a same model broken camera is easier than to look for the schematic and ICs. Try ebay and other local sources. Somebody may sell it for parts.
Aug 20, 2009 | Cameras
Pentax Optio M60 Digital Camera Logo
80 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
