SOURCE: Need to enter service mode on a Xerox 7435
The service tech should do this. The 7435 should be less than 3 months old, and Xerox should fix it. If you bought it from Global, or another company that does not actually employ Xerox technicians, try appealing to them, but I cannot tell you for sure what the outcome will be. Buying from an authorized agency ensures that you can use your "Total Satisfaction Guarantee".
SOURCE: Xerox 7435 error code 010-328 whtes the problem
it is the code for fuser heat control problem. Usually, the unit has its airflow restricted try moving the unit or cleaning it to see if the problem clears
Here is a list of all the error codes
WorkCentre 7425 style Fault Code List Part
SOURCE: How Do I Reset Counters of Xerox Workcentre 7435 Toner Chips ?
You can't. It is hard wired in programmed memory. The reason is because most Xerox printed are supplied on a consumables deal where you have to buy toner direct at a slightly inflated price to cover the lowered lease cost of the machine. These machine also 'phone home' for interrogation..
Testimonial: "Some Next Model machines ex. 75xx , 78xx , 79 xx Will have reset toner levels in programming."
