Question about Kodak Imaging Professional Edition 2.6 Full Version for PC
How to install kodak imaging ocx on windows vista
Htmlmarq.ocx unable to register in systems registry
Open regedit and browse to this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
You should see htmlmarq.ocx and htmlmm.ocx separate keys. Rename them to something else, ie. htmlmarq.tmp and htmlmm.tmp.
You will now be able to install Office 97, including the HTML option, without incident.
Mar 05, 2010 | Microsoft Word 97 Upgrade Version for PC
I cant install all in one software in my vista
It is due to the compatibility settings of Windows Vista. The Kodak software has been designed for use in Windows XP, when you try to install the software in Windows Vista there will be compatibility problem . First of all search for the software which has the Windows Vista support.
Nov 14, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Will not let me install new printer ESP-5 CD
Kodak printer ESP-5 CD version 3.2 is not compatible with Vista. You will need to upgrade to Firmware 4.3 Windows XP/Vista from Kodak Printers. The drivers may be found here:
http://www.opendrivers.com/freedownload/280436/kodak-esp-5-all-in-one-printer-firmware-4.3-windows-xp-vista-download.html
Jul 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
QV ver6 (Win 95/98/NT) compatible with Vista?
If you right click on the shortcut and go to the Compatibility tab you can check the Run this program as an Administrator option. This worked for me.
Jun 23, 2008 | Parsons QuickVerse 2005 Expanded Edition...
DLL Install Conflicts
if you have install any application then unistall the application
Jun 11, 2008 | IBM ThinkPad T42 Notebook
Video viewing
If you have not yet installed Kodak's EasyShare Software, start there. With that, you can view, organize and even edit (trim) still and video images. Versions 6.4 and up are Vista compatible. You can then transfer in new images from the camera or add any images that you already have on your PC.
DigiChick
Jun 05, 2008 | Cameras
Error with Vista
If you are using any other operating system than Vista please see this article: http://www.rebrandsoftware.com/admin/supportEdit.asp?article_id=53
This error indicates that a file is not correctly installed on your system. In some cases it may be correctly installed for all standard users but not for the "Administrator" account, and you may only see this error when selecting "Run as Administrator".
The built in Administrator account is not intended to be used as a user account. It is very secure and will not allow program components to be registered. Instead you should create an account with administrative rights, and use it instead of the built in Administrative account. This will help solve runtime error 339/429 on our software, and lots of other software that you may install in the future. If you do not want to create a standard user account (not recommended) you can follow the instructions below:
If the problem started suddenly then a reinstall may fix it. If not, follow the directions below to register each file that is producing the error. You generally will only have to repeat the instructions 3 or 4 times:
Click start
In the search box type "cmd" without the quotes
When CMD.exe appears above the search box right click it and select "Run As Administrator". This will open a command prompt with admin rights.
Repeat the following for each file that is causing this error, replacing [filename] with the actual name of the file that is causing problems:
    -Type "regsvr32 [filename] /u" without the quotes
    -You will receive a prompt saying the file has been unregistered. Click OK.
    -Type "regsvr32 [filename]" (shortcut: press your UP ARROW and delete /u)
    -You will receive a prompt saying the file has been successfully registered.
    try this
    Go to Start
    click Run
type in cmd
press enter
type in the black screen
regsvr32 MSWINSCK.OCX
Press enter
it will come back the c: prompt
then
Restart your PC
Jun 02, 2008 | Microsoft Windows Vista Ultimate Edition
Registering msdatlst.ocx and msdatrep.ocx in Vista
This may help to find the reason why msdatrep.ocx is not registering. Try http://www.dependencywalker.com/ download, run it and tell it to be associated with .ocx files too. Than you can right mouse click on msdatrep.ocx and say "View Dependencies" - any missing dlls will be in red. This may help to find the reason why regsvr32 is not working.
Sep 09, 2007 | Microsoft Windows XP Professional With...
Kodak Imaging Professional Edition 2.6 Full Version for PC Logo
1,115 people viewed this question
Top Kodak Computers & Internet Experts
gaucherre
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kodak Computer and Internet Expert? Answer questions, earn points and help others
