SOURCE: Tab printing on Xerox 7345
There is no tabs option on the 7345. I am glad you asked that.
I was recently at school on that product, there was no mention of tab printing, I went to the Xerox.com site to inquire and tab printing is not supported.
You can call 1-800-821-2797 and inquire there. They may have an undocumented solution for tabs.
Let me know if they do please.
You will need your machine serial number when you call.
SOURCE: xerox 7345 color
If you go into your User settings. Login 11111.
What you want to do is the Auto Gradation adjustment. It will print out a test pattern and you will place it on the glass and scan it.
I think there are 4 times you repeat it, for copy, print, photo print.
That should correct it. There is also a Tec Color adjustment on your print driver if the issue is only when you print.
SOURCE: Xerox 7345 red comes out orange. Performed auto
the wrinkles sound like the fuser, how many copies on the machine? when was the last service? copiers are like cars they need to have there maitenance
Testimonial: "Exactly what the Tech. said when he arrived. Thank you. Great info, right on."
SOURCE: I have a Xerox 7345. Instead of printing red it
In one of these diagnostic areas you will find an auto gradation adjustment, perform that. Here are the steps.
To enter the CE mode:
The CE Access Number screen will appear.
WC73XX only: Select a paper size and type using the paper supply button
SOURCE: Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox
Phaser 7300 Misregistration Issues
I hope this helps!
