Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Is there a degauss built into the Sony Trinton Wega 28" tv?
    Novelist:
  • 85 Answers
Since all Trinitrons have a steel/iron slot mask that the in-line beams shoot through they have to have a de-gaussing coil. It is only on for a few seconds but without it you will have (dis)coloration of regions of the screen. The coil is in series with a thermistor or like to limit the current to a short time. As the slot mask can be bent in only one plane and is near the glass, the glass has to be thick to support the air pressure on the straight-line surface. That's why they are so heavy. -Ken
Posted on Jul 27, 2009
  • 4,234 Answers
Yes. There are degausing circuits built in that are triggered during the powerup sequence.
Dan
Purple tint on corners of television screen
It needs degaussed. Turn the TV off for 24 hours and unplug it. Plug it back in and turn it on. If the degaussing coil in the TV hasn't worked buy a cheap degaussing wand off of ebay. 10 second fix. You can also ask the local repair shop to do it. Anything over $5 I would just buy the wand. Keep magnetic objects as well as electronics away from the TV. Vacuum cleaners can also cause this if it's on the floor.
Dec 28, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega tv codes
Codes to check are:
0128 0013 0002 0071 0380
Apr 23, 2012 | Sony WEGA KV-28HX15 28" TV
My Sony WEGA Trinitron 36'' TV has red instead of green, how do I reset the picture or fix this?
try this reset in this see if it works
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Mar 06, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
Sony trinton 27inch red light blinks 11 times
those LED flashhing codeds are useless. You most likely have a problem in the high voltage circuits. You should bring that one to a local shop as it's very nlikely you can fix it yourself, and the high voltage circuits are dangerous.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green corners of sony crt tv
thats kind of degaussing coil not function, try to replace that one and lest see what the re action of your tv.
Apr 16, 2009 | Sony FD Trinitron KV-28FQ75 28" TV
TV has color bloches at corners
Assuming this is a tube style TV (not lcd flatscreen) your degausing coil in your TV sounds like it is defective . The Degaussing coil on newer televisions / monitors surrounds the outside edge of the TV and turns on when the TV is fired up. In the old days, their used to be no degaussing coil - when a child would take a magnet to a CRT television, magnetism would remain on the tube and cause discoloration and blotches as you describe (multi-colored blotches) To correct this a technician used to use a degausassing coil and perform a circular pattern on the screen to remove the improper magnetized area. Since the old days, newer tvs have degauss coils built into them, but if they go bad, or always on etc... they can cause the problem you describe.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Television picture colour
This is because you have something emitting an electric magnetic pulse close to the TV. Like a large unshielded speaker or large Battery. First thing you need to do is move anything near the TV away and see if that correct the issue. Next would be to degauss the TV. Unfortunately the TV probably does not have a built in degausser.
A degausser is an electro magnet in a circle. you plug it in and run it around the surface of the TV.
Mar 20, 2009 | Beko 324250WN 28" TV
32" Sony Trinton Wega
Count the flashes and verify that the model is KV-32FS100. The flash count will indicate the circuit in which the problem was detected.
Thanks,
Dan
Oct 28, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Blinking
hello
It sounds like it is trying to start but is unable to.
these sets have bad horizontal output transformers.
you need a tech to solve this one.
Thanks Guy9
Jun 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
207 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
