Hi my internet explorer is running with add ons disabled and i can't see pictures or watch videos or do anything i used to do before it happened, i have tried many things but it doesn't work, when i go to the yellow bar it doesn't give me the option "manage add ons" it only shows about add ons and more info, i uninstalled internet explorer 8 as i've been told to do and installed ie7, still the same problem, i have no idea what to do anymore as i don't understand much about computers, i just want my internet explorer back as it was before. i do want to block flash ads each time i go to my hotmail but thats all, now the whole computer is not working properly, please help me, if possible, step by step. i want to have activex control.
  • 37 Answers
You have downgraded to IE7 but your IE8 setting are still active in the background you need to do a system restore to the last point when you setting worked fine that should fix the problem
Posted on Jul 27, 2009
Internet explorer crashes
If Internet Explorer is crashing , your dilema likely lies with a buggy browser add-on. However, Internet Explorer crashes can have a alot of other causes, including incompatibilities with hardware rendering and possible malware.
crashes are often cause by buggy add ons. you can check to see if that is the problem by running internet explorer with out add ons
To do so, open the Start menu and launch the All Programs > Accessories > System Tools > Internet Explorer (No Add-Ons) shortcut.
If running Internet Explorer with no browser add-ons fixed your problem, you can disable the add-ons one by one to identify the one causing the problem. Click the gear menu and select Manage add-ons to open the Manage Add-ons window.
Select an add-on in the Toolbars and Extensions category and click the Disable button to disable it. Disable add-ons one by one - or disable them all and enable them one by one - until you identify the add-on causing the problem.
malware can often be a problem with applications crashing especially for an browser like IE. so scan your system with antivirus software for sure.
Mar 23, 2014 | Google Toolbar
Tip
Internet Explorer 8 takes longer than expected to start.
Symptom:
When launching Internet Explorer, you may notice that Internet Explorer takes longer than expected to start.
Cause:
This issue can be caused if there are damaged or incompatibilities with installed Internet Explorer add-ons. This behavior may be more visible in Internet Explorer 8 due to changes in the way that Internet Explorer 8 handles the internet zones list.
This issue can also be caused if using Spybot and the Spybot immunization feature is enabled.
Resolution:
To resolve this issue, troubleshoot the Add-ons to determine which Add-on may be causing the issue and then disable or uninstall the Add-on and then contact the manufacturer of the Add-on for support with that Add-on.
To do this, follow the steps listed below starting with Step 1.
Note: If you currently have Spybot installed with the immunization feature enabled, you will need to disable that feature until that issue is resolved. If you’re not sure how to disable the immunization feature, contact the vendor for more help.
Step 1: Run Internet Explorer 8 in "No Add-ons" mode to determine if the issue is Add-On related.
loadTOCNode(2, 'resolution'); Internet Explorer 8 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 8.
To determine whether the error is caused by an add-on, run Internet Explorer 8 in "No Add-ons" mode. To do this, follow these steps:
  1. Click Start, and then type Internet Explorer in the Start Search box.
  2. Click Internet Explorer (No Add-ons). Internet Explorer 8 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Step 3.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 8. In this case, continue to Step 2 to determine what Add-on is causing the issue.
Step 2: Use the Manage Add-ons tool to determine which add-on is causing the issue
loadTOCNode(2, 'resolution'); Use the Manage Add-ons tool in Internet Explorer 8 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  1. Open Internet Explorer 8.
  2. Click Tools, point to Manage Add-ons , and then click Enable or Disable Add-ons.
  3. In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
  4. For each item in this list, select the add-on, and then click Disable under Settings.
  5. When you have disabled all the items in this list, click OK.
  6. Exit and then restart Internet Explorer 8.
  7. If issues do not occur, repeat steps 1 through 3.
  8. Click Enable for a single add-on.
  9. Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
After you have used this process to determine which add-on is causing errors, you can disable that add-on. Or, you can uninstall the software that installs the add-on. We also recommend that you contact the software vendor that provided the add-on for additional troubleshooting and support.
Step 3: Reset Internet Explorer 8 settings
loadTOCNode(2, 'resolution'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 8 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled.
  2. Click Tools, and then click Internet Options.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
The information in this article applies to:
  • Windows Internet Explorer 8
Keywords: MS Article ID 969938
on Mar 29, 2010 | Computers & Internet
Can not download yahoo toolbar "Internet Explorer
Internet Explorer's Add-on Management feature lets you view, enable and disable the list of add-ons which can be loaded by Internet Explorer. Add-ons include browser helper objects, ActiveX controls, toolbar extensions and browser extensions.
To view or modify the add-ons on your computer by launching Manage Add-ons:
1. In Internet Explorer, click the Tools button, click Manage Add-ons, and then click Enable or Disable Add-ons. 2. To disable an add-on, select it in the list in the Manage Add-ons dialog box and select the Disable radio button. 3. To enable an add-on, select it in the list in the Manage Add-ons dialog box and select the Enable radio button. 4. Click OK to confirm. Note: Disabling an add-on does not remove it from your computer. It simply prevents Internet Explorer from executing the add-on's code-it does not prevent other software from executing the add-on. If an add-on is disabled, website pages that rely on that add-on may not work as expected. For more information on Add-ons, click the "Learn more about add-ons" help link in the Manage Add-ons dialog box.
Oct 01, 2011 | Dell Dimension 3100 PC Desktop
Im not getting *** videos
1.Watch videos at off peak times, if possible 2.Do not run other programs while watching videos. They slow down computer ingeneral by making use of memory. 3.Add RAM on your computer. More RAM will make easy execution of heavy programson your system. 4.Get better and speedy internet connection. Talk to your ISP in this regard. 5.Regularly clean windows registry. Windows registry is vital place that storesinformation for important computing functions. A congested or corrupted windowsregistry makes computer slow that causes YouTube like freezes. For this, getthe best registry cleaner RegInOut cleaner and optimizer. Use it once in afortnight for fast computing to avoid YouTube freezes and system slow down.
Feb 25, 2011 | YouTube Videos
Internet explorer is currently running without add-ond disabled
Follow the steps below to Enable the Add-on
To re-enable an add-on in Internet Explorer 8
  1. Open Internet Explorer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, and then clicking Internet Explorer.
  2. Click the Tools button, and then click Manage Add-ons.
  3. Under Show, click All add-ons.
  4. Click the add-on you want to enable, and then click Enable.
  5. Repeat step 4 for every add-on you want to enable. When you are finished, click Close.
To re-enable an add-on in Internet Explorer 7
  2. Click the Tools button, point to Manage Add-ons, and then click Enable or Disable Add-ons.
  3. In the Show list, click Add-ons that have been used by Internet Explorer to display all add-ons.
  5. Repeat step 4 for every add-on you want to enable. When you are finished, click OK.
To DISABLE ADD-ON
To permanently disable add-ons in Internet Explorer 8
  4. Click the add-on you want to disable, and then click Disable.
  5. Repeat step 4 for every add-on you want to disable. When you are finished, click Close.
To permanently disable add-ons in Internet Explorer 7
  5. Repeat step 4 for every add-on you want to disable. When you are finished, click OK.
Follow the steps below to run Internet Explorer with all add-ons temporarily disabled. Add-ons will be disabled only until you restart Internet Explorer normally. To disable add-ons permanently, follow the steps in the section above.
To temporarily disable all add-ons
  1. Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, click All Programs, click Accessories, click System Tools, and then click Internet Explorer (No Add-ons).
The above steps will solve the problem.
Thank you for contacting FixYa
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | Acer Aspire One PC Notebook
Downloaded a patch. May have installed wrong. I try to edit picture album to add picture. All I get is text programing info, but will not add pic.
Hi!
What patch were you trying to install??
Adding/editing pictures to Facebook uses Java platform. Uninstall ALL Java installations on your computer (look in Add/Remove Programs - on Windows XP or Programs and Features on Vista/7), then download the latest version of Java from here.
Close all browser's instances and install Java. Once installed, open Facebook and try again.
An add-on might causing this problem. In Internet Explorer, go to Tools -> Internet Options -> Programs tab -> manage add-ons. Disable any suspicious add-ons and click OK when done. Restart Internet Explorer then try Facebook again.
Also, try cleaning browser cache (in Internet Explorer, go to Tools -> Internet Options then click Delete under "Browsing history section"). Restart your browser and try again.
Alternatively, I would recommend using Firefox, as a replacement for Internet Explorer! You get get it here
Hope this will help you...
Regards,
Pelu.
Mar 30, 2010 | Facebook Computers & Internet
Internet explorer unhandled third party exception
Are you using IE7 or IE8? In XP and Vista they should install an Internet Explorer (No Add-ins) option. In XP it is installed to All Programs>Accessories>System Tools. Try running that option - if all is okay without add-ins then it is one of these going wrong. You can manage the add-ons through Control Panel>Internet Options. On the Programs Tab Hit Manage Add-ons at the bottom. Disable any non-microsoft ones and start IE. You can then add each one back in one at a time until the issue arrives again. When it does disable that Add-in and you should be okay.
Jun 03, 2009 | Computers & Internet
IE8 freezing/crashing
Hi there.
Don't bother with IE8 at the moment because there are too many bugs with it.
Either go back to IE7 or use mozilla firefox 3.
Thanks for choosing FixYa!!
Jun 02, 2009 | Microsoft Internet Explorer 8
White screen suddenly appears Blank Page Windows
Try these steps first. I assume you are using IE 7. If these steps do not work try reinstalling your IE. Let me know if you need anything else. Good Luck.
Method 1: Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
  1. Open Internet Explorer 7.
  2. Click Tools, and then click Delete Browsing History.
  3. In Delete Browsing History, click Delete All.
  4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK.
A progress bar is displayed to indicate that the browsing history is being cleared. After this process is complete, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 2.
Method 2: Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK.
After you do this, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 3.
Note If this method does not resolve the issue, you can restore Internet Explorer 7 to its previous security level.
Method 3: Run Internet Explorer 7 in "No Add-Ons" mode loadTOCNode(2, 'moreinformation'); Internet Explorer 7 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 7. To determine whether the error is caused by an add-on, run Internet Explorer 7 in "No Add-Ons" mode. To do this, follow these steps:
  2. Click Internet Explorer (No Add-Ons). Internet Explorer 7 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Method 4.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 7. In this case, use one of the following options.
Option 1: Reset Internet Explorer 7 loadTOCNode(3, 'moreinformation'); Reset Internet Explorer 7 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled. To reset Internet Explorer 7 settings, use Method 4.
Option 2: Use the Manage Add-ons tool to determine which add-on is causing the issue loadTOCNode(3, 'moreinformation'); Use the Manage Add-ons tool in Internet Explorer 7 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  2. Click Tools, point to Manage Add-ons, and then click Enable or Disable Add-ons.
  6. Exit and then restart Internet Explorer 7.
Mar 13, 2009 | HP Pavilion dv4000 Notebook
Can not install flash player
You might want to re-enable a browser add-on if you disabled an add-on but want to go to a site that requires it, or if disabling the add-on caused general display problems with webpages or Internet Explorer.    To re-enable an add-on
1.     Open Internet Explorer by clicking the Start button , and then clicking Internet Explorer.
2.     Click the Tools button, click Manage Add-ons, and then click Enable or Disable Add-ons.
Jan 03, 2009 | Adobe Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
