SOURCE: MIxer quit working while mixing 3 batches of oatmeal cookies
Hi. Kitchenaid's warranty is 1 year.
Most likely, the plastic transmission housing has failed, causing damage to the working parts inside your mixer. Take it to a local repair place and have them work up a quote to repair it. It will take at least a month to get the parts.
If this solution has assisted you, please rate it. ricardok45
I
SOURCE: H600 Hobart mixer Machine does not run
sounds like you are overloading mixer.cut back on batch size
SOURCE: 4.5 quart. Why doesn't it turn on?
It is not turning on because the power is not getting through the entire circuit. First easy thing to check is the carbon brushes under the black screw caps on the side. If they are worn out just replace them. They are keyed with one corner shaved off so line the key up with the blocker inside the hole where the brush goes. Use a torch to look in there to see it in one corner right at the bottom. You could also remove the back cover and make sure there are no broken wires there, it's not uncommon for one of the bottom wires to break off by the plate they plug on to.
