SOURCE: I WANT TO KNOW THE MEAN OF
If LCD displays Error 06 or Error 09 , the TMA might require service
Press SCAN PICTURE button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected).
NOTE:
The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
SOURCE: What is an error 06
The bulb needs replacing. Check this: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=c00022537 for errors .
