Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
Yes. You can definitely speed up your Huawei modem using WiFi booster. You can get WiFi booster at low cost online and install it at your desired location to speed up your Huawei WiFi modem. You can check the change in your internet connection speed after installing a WiFi booster by having a speed test at ScanMySpeed.com good luck.
Firstly test the laptop pc at another wifi hotspot. If it works, your wifi modem might be faulty. Try testing the wifi modem with another device like another pc, tablet or smart phone that has wifi capabilities. I exprienced a modem that had both LAN and wifi. The LAN connected to the internet, but wifi could non. After replacing the modem my problem was solved. Hope this helps.
many user faced that kind of problem.. but 99% is from the simcard provider ... go to simcard provider center.. they are free to assist all of the problem about their network or simcard..
Dear vinod ,this is not a driver related problem,error 721comes only when your having network issue or your account is disabled from tata indicom's system,plz vist any tata indicom outlet to check your accounr
