Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
BIG SCREEN PROBLEM
By jpallotta3 on Nov 22, 2007
Happy thanksgiving! My name is Joe and I turned my tv on today only to hear a poping sound coming from the rear panel and no picture. Well, I'm a
little tool wise so I took the lens asembly off and cleaned it thinking it might help, it didn't. The arc is coming from that part that resembles a spark plug cap, its poping and an arc is jumping aroud that cap. Can I fix it or is it history?
Comments:
Nov 30, 2007
- Hello T,
Thank you very much for the response. Your help in this matter is truly appreciated. I will get back to you will the info later today. I have some more info on my problem. After seeing the arc coming from the "spark plug cap" as I call it, I replaced it with one I recovered from another RCA tv, This remedied the problem for about 4 hours only to have the arcing problem return with the new part. I cleaned the area real well with alchohol but didn't apply the silicone stuff cause I didn't have any. Also , I broke the shield that covered the cap but I replaced it with a thick rubber piece I made.Will this rubber piece be enough?. Again thanx for the respomse and I look foward to fixing this problem ..
Joe
Dec 01, 2007
- PROSCAN........R.C.A.........52"......MODEL#PS52682....................
SERIAL#PTK171ACB......DOLBY PRO LOGIC..........199? CAN'T READ LAST NUMBER IN YEAR........THREE COLOR UNITS...CENTER ONE THE PROBLEM....HELP............
THANK YOU "T"
jOE
Best Solution
posted on Nov 23, 2007
Helpful)
Terryfic
Rank: Guru
Rating: 87%, 1713 votes
There is no such thing as a generic problem to a technician !
Please state Make,model,age, service # off back of set and then
I can help you..Thank you,Joe.........................T.
Comments:
Nov 30, 2007
- PLEASE provide info requested.............
AND provide same info from "borrowed" xformer set........
parts that are physically alike aren't always electronically
compatible.........
Do not seal with silicone rubber...................
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
i think i have a bad bulb but i'm wondering what my other symtpoms suggest. on power up, click... (More)
Answer
high voltage power supply ceased operating How much would it cost to replace?
Answer
My RCA D52W23 attempts to come on,emits a slight sound, then turns off. It does this several times... (More)
Answer
I have a Mitsubishi medallion 65'' big screen, model ws65411. It turns off by itself. I can turn it... (More)
Answer
60pp935217 how do I hook up the HD to cabel box....... no HDMI port. only HD input AV5
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
