Digimate L1918 (12volt)not activating the screen
The monitor switch lights up when activated but just flashes on&off it also makes a clicking noise but will not activate the screen
    Sergeant:
  • 396 Answers
Try using another monitor instead. If that one doesn't work either, then check out the video card. If you have an add-in card then change it out with a known good one. If not install one and then see if it helps.
Posted on Jul 30, 2009
I have hp pavilion dv2000, when I plug in dc cord it switches on without pressing power switch. Than I'm able to switch it off and on. All lights on panel and motherboard switch on also. CPU fan switches...
dv2000 zero support now at hp,
2006? year.
so does the VGA port on the rear of PC work. to a desktop monitor
yes, then the mobo is ok. but not screen.
easy no?
i can make the mobo run on a table. vga connected.
with Fn+F4 toggled on and external USB keyboard, I can activate the external screen.
steps. are as follows. in proper order
1: remove that shorted huge battery, there. get it out of there.
2: make sure the power pack reads (VM) 19vdc at the jack.
3: new coin cell if voltage on its pins below 2.9v... yah?
4: get BIOS screens working FIRST. disconnect HDD and DVD drive. now.
5: go to 1 ram stick bank 0 (try 2nd one by self)
6: does the flashlight trick work on that CCFL screen,?
7: remove all modules from MOBO cept CPU and 1 stick RAM?
we call that the strip down tests.\
8: beep codes, or Caps lock key flash codes? what?
BIOS screens have to work, or mobo is dead.
has anyone been playing with BIOS doing crazy things like flashing it.>? yes, oops now you bricked it. then what (ask)
if pc is 2008 that is the solderball from hell year.
see that and the CCFL test here.
http://www.pcdied.com/monitors.html#flashlighttest
Aug 16, 2017 | HP 417035-001 - HP Pavilion dv2000 Series...
Hi. the mobicam keeps turning on and off and the light is flashing?
What does the VOX switch do?
When the VOX function is active, both the LCD screen & Audio turn off and will automatically reactivate when there is
noise in the room being monitored (e.g. baby crying). This feature is useful at night so the light coming from the screen
doesn't bother you and also when running the MobiCam Ultra receiver on batteries since it will extend the life of the
batteries. Note: The VOX function will not work when batteries are low and you cannot change channels on the receiver in
the VOX mode
Jun 14, 2011 | Mobi-Cam Mobi AV Monitor
Hi i have a packard bell fsp250-60gen when i switch it on it clicks and a blue flashing light which looks like a bin shape and it sends no signal to the monitor
The bin light is I think the hard drive activity light. Try booting this to an external monitor if that works, the issue is with the screen or inverter, of it does not work, the issue is with the graphics card
Jan 25, 2011 | Computers & Internet
Can't get laptop to connnect to monitor
Your laptop may very well have a function key that turns the VGA socket on at the back of the laptop.
Also you will need to check in display properties that the secondary monitor is enabled.
If you need more help post a comment with the make a model of your laptop.
Nov 09, 2009 | Sony MFM-HT205 20 Flat Panel LCD Display...
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
ON/OFF SWITCH JUST FLASHING ON MONITOR
then the backlight or the inverter inside the LCD is bad. Replace or repair
Don't forget to rate the advice!
http://www.aa1consulting.com
Jul 26, 2009 | Computers & Internet
My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Dec 11, 2008 | Acer TravelMate 2451WLMi Notebook
Monitor is connected to laptop jack and displays "no signal"
You have to activate the video out of the laptop.
Two ways to do this depending on how you want to use the monitor.
To use the monitor by itself laptops have shortcut keys.
Usually they involve using the Fn key and one of the F keys (Usually F3-F4-F5) KEy will either show two screens or say CRT-LCD
Pushing both keys at once will switch you to both screens, pushed again will just run the monito, Pushed again will return you to the laptop screen.
If you want to use the monitor as an extension of the monitor to be able to drag windos over to it then go to your display properties from the control panel and activate the monitor in the settings box. You'll have to click the monitor first then activate it as a extension and adjust the resolution here.
Fran
Oct 16, 2008 | Acer AL1916W 19" LCD Monitor
Black screen
One way to test it is to connect a monitor to the VGA port (make sure to activate the external monitor (Fn+monitor key)
If it does work on the external monitor, I would look at replacing the onboard LCD.
If it doesn't, you are looking at problems with the onbaord video.
Aug 05, 2008 | Toshiba Satellite A105-S4334 Notebook
Dead compaq laptop, no boot activity
Larnold..Sounding like you need to check the LCD Power Inverter Circuit board.. this is located inside the screen a long rectangular circuit board that sends power to the screen backlight & Display Panel.. Could also be a Bad Backlight.. Try Booting it.. Hold it up to a light and look closely at the screen.. If you see a faint image but no light, it is the Backlight, if Just Black No Activity then its most likely the Power Inverter, OR a Bad Video Card.. You can test the VIDEO by Connecting the laptop to a Computer Monitor or similar with the laptops VGA Serial port.. then Use your function Key and Switch to 2nd Display.....(one of your F keys.. ).. If it Shows up on another screen, Its a Display problem and not the video card... Hope This Helps alittle.. Cheers
Jun 02, 2008 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
