Vulcan Quasar 40 air issue
Our Vulcan Quasar 40 was merrily working until suddenly it started playing up. The first thing I noticed was that the top of the heater was getting hot, and then after a few minutes the entire unit would stop. I assume the unit is stopping due to the thermostat, however what I did notice is that no air is coming out through the air deflectors.
I am guessing it may be blocked or similar so heat is going up into the heater and due to the thermostat is quickly just turning itself off and then on again. Any thoughts on how to fix this?
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Posted on Aug 12, 2009
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Sep 01, 2011 | Heating & Cooling
Pilot on, gas fires up, no fan comes on.
Sounds like you are talking about the indoor fan that circulates air through house. Turn the unit off and make sure the fan rotates freely. Next check the capacitor for the fan. If it looks swollen its probably bad. If it doesn't look swollen then you will need a multimeter to check it with. If that's ok then check the fan relay. Let me know what you find.
May 30, 2010 | Heating & Cooling
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Vulcan Ilec central heater main burners turn off after few second
Flame rollout sensors, overheat thermistor, air proving switch, bad earthing, blocked flue. Any of these things can cause your problem. If its a permanent pilot, is it clean burning?? If electronic ignition, is the flame rod clean i.e. no carbon or rust etc.. Safest bet is a qualified gasfitter take a look at it.
Jul 02, 2009 | Heating & Cooling
Vulcan quasar 40 shut down when fan starts up
Replace the fan thermal switch located at the top of the heat exchanger. Unplug the power first as the switch is 240V.
Available from any plumbing trade shops e.g. Reece & Tradelink
Jun 03, 2009 | Heating & Cooling
I have a vulcan quasar wall furnace. the fan no longer works
Perhaps the fan motor is bad. If not, you have an electrical problem.
Jul 23, 2008 | Heating & Cooling
Vulcan quasar elite heater does not display led readout or any lights when plugged into power point the point and switched on.
this is not an air conditioner but a fan forced heater. The control unit has died and a replacement is over $170.00 !! It's going to be recycled.
Heating & Cooling Logo
620 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
