Question about Hoover F7210-900 SteamVac V2 Upright Wet/Dry Vacuum
Just bought the above mentioned steam vac.
It was a reconditioned vac that (I was told the brush moter was replaced)
So, I fill it with water.... Turn it on...and no water comes out....
You think the prior owner might have burned something else out other than the brush moter?
Thank you in advance.... I am taking it back to the place I bought it.... Just wanted to sound intelligent with a suggestion when I take it back.
  • 1,673 Answers
Re: Hoover F7210-900 SteamVac
Before you take it back, check the filter inside the lid of the recovery tank, if it is all of the way to the top, it will cause problems, it needs a 1/4 in. gap from the top. Might be also that the plunger in the handle is pushing all of the way down so as to release the water.
Posted on Feb 05, 2008
0 characters
3 Points
The Hoover steam vac dual v does not spin its brushes and I dont know how to dismantel it to view the belt .
There is no belt on the steam vac - it operates on air flow. Remove the brush and insert a flat screwdriver into the square hole. If it does not turn, the turbine has seized up and must be replaced. Remember that the brush will not turn unless the lower tank is in place, and the handle is tilted back.
Jan 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
New Hoover Steam Vac's brushes do not spin
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Turbine Brush Gear Part # 43191008
F5914 Parts Link
Feb 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
How do I clean the nozzle of my Hoover steam vac Jr?
No, this assembly can only be rinsed under running water.
Sep 29, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
I have a hoover steam vac dual v. The brushes will not rotate
The brushe holder is not snapped in correctly. You have to push it in hard.
Aug 20, 2009 | Hoover F6213-900 SteamVac Agility...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F425-900 Steam Vac V2
Check the brush block to make sure that the shaft going into the turbine is ok, if it is, then the turbine will have to be replaced.
Dec 29, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
If you used any other cleaning solution other than Hoover, your Steam Cleaner will develop deposits in the turbine that drives the brushes. What happens is this:
Users pour other store bought brand cleaners in the reservoir to clean. Then they store the Hoover Steam Vac. While sitting in storage, the residue dries in the turbine and develops hard deposites, which ruins it. It will cost you about $100 to have the Hoover Store repair.
Cleaning Solution:
Oct 14, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F7210-900 SteamVac V2 Upright Wet/Dry Vacuum Logo
166 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
