I just broght a Bose LS 48 / SL2. For most of the DVD's I have the set says "wrong DVD region code"!!! What do I do? All these DVD's play on other DVD players - if the region code is wrong, they should not play on other systems also. Can I reply on [email protected]?
Follow this button sequence press when the error message appears"
Right Navigation - Up Navigation - Shuffle - Stop - Mute
this is make is play all discs.
It appears some are either aftermarket or personally recorded DVD's that's causing the issue.
That Bose player is a universal player and it's settings specific. Check your region code / setting as United states uses NTSC and foreign countries use a couple others.
As well as check disk format as there's a huge difference between a player trying to play standard disks as opposed to Blu-ray.
Neither of this seems to be working for me. I have a Lifestyle 38 III series. Any help?
How will i resume the ntsc,because i accidentally switch it into pal mode.i can change it back
Thnaks jazz6er - all DVD's I have are purchased and not personally recorded or pirated. Also all of them are purchased in either Dubai or Qatar. I stay in Qatar. DVD Region Code is 02.
