On Doro 626 phone the ear piece not working.Loudspeaker works. Tried plugging and unplugging headset. Would like to either solve problem or to always use loudspeaker by default. Suggestions? Thank you
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
hey kev..
all i can ask you is ... the following
1) open the ear piece of the non working .. then take a multimeter (keep meter in resistance mode) and check the resitance if its good it will show you.. apx 32 0hm and if its showing you 0 or .1 or below 16 ohms..
2) after you disconnect the speaker.. the broken one that is... chek the cable connectivity.. or rather continuity.. for this keep the meter in continuity mode the pervious resistance mode.. then take one wire and connect one prob from meter to it.. and take the other prob and connect ti too the pins of the cnnector.. ( here is there are 4 pins dedicated to the ear phone.. 2 for each.. nd they are towards the end sid.. just below the # key.. frm # key the last 4 pins connectors are for audio.. ) check the.. pins on the cord connector not the phone..
i hope you can find what wrong with your... head set now.. and yeah
if the speaker is out jsut replace both the ear piece with sony or aiwa earphones.. it wil work best
if your cable is gone then all the best buy a new
one
tc
aditya
There is no problem with your phone's main speaker from where you can hear your ringer, tones and media files, including calls put on loudspeaker. The problem is the ear piece speaker of your phone.
