Question about Sony Playstation 3 (PS3) Console
Squares appear when i play games
Today my computer was running fine. I recently tightened the hinges in my laptop screen because it was getting quite loose. Later that day, i opened my graphic properties, i didnt touch any settings, i didnt change anything, i went to 'Adjust image settings with preview' or something like that, and the image had weird checkerd squares tiled all over it.
Please reply, because i am getting worried since this is my only computer and i dont have a lot of money to replace it.
Dell Vostro 1500
15.4" Widescreen 1280x800
2.0Ghz
3.5Gb RAM
512Mb Shared Graphics or 256Mb Dedicated
Windows XP 32 Bit
Wi-Fi 802.11g
Bluetooth
160Gb SATA Hardrive
    Scholar:
  • 85 Answers
Try updating graphics card driver
if that does not fix, then try to restore it to previous date when it was working
Posted on Jul 27, 2009
Little green squares appear in video playback
Had the same problem, usually when trying to upscale video ! Try reducing size of video on laptop when using transfer software, see if that helps. With my aged laptop, problem seems to be because my laptop has an extremely slow processor chip, and it just can't keep up with the video !
The software I use, which is free, is Freemake Video Convertor, which gives you a choice of output formats and sizes.
Mar 16, 2016 | Canon ZR Video Cameras
Why is my laptop crashing?
I would try getting the latest video card drivers first, if it is a Nvida card & it has recently updated itself, I would roll back the drivers, there has been a problem with the last update & my computer didn't like the upgrade & blue screened a lot, but was fine after I rolled them back in safe mode, if the problem if not repairable via software then go to a Laptop specialist, for what its worth I think its a software issue as you say its only when playing games, but im not an expert just well informed.
Jul 11, 2015 | Computers & Internet
??? My LG 50PN4500 TV has a strange one-time issue, I turned it on last night (was on standby) and a full screen "shadow" pattern of squares appeared? They were gray but I could see the colour...
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 12, 2017 | Televison & Video
I have dell inspiron 1525 laptop , i am recently facing the problem that laptop hinges are shaking 5 to 10 mm front and back . other than this everything hardware and software are fine
the hinges screw into the laptop case. They've probably come loose through normal wear.You'll have to open the laptop case and tighten the hinge mounting screws. View or download the service manual at the following link:
http://support.dell.com/support/edocs/systems/ins1525/en/index.htm
The service manual will show you how to disassemble the laptop so you can get to the hinge mounting screws. Look under "Display"-->"Display Assembly" in the manual.
Apr 12, 2011 | Dell Inspiron 1525 Notebook
How do i tighten my screen on dv 1000 it is too loose with too much play
Hinges on laptops cannot be tighten, they need to be replaced.
For parts and details how to replace hinges please click on these WEB sites :-
Replacing Display hinges http://www.laptopparts101.com/display-screen-hinges/
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
Mar 11, 2010 | HP Pavilion dv1000 Notebook
On opening dell inspiron 1300 screen stays blue mess
2 things, reseat the video cable (Under keyboard), and tighten all screws in and around the hinge assembly (LCD Grounds through the hinges)
Sep 23, 2009 | Dell Inspiron E1505 Notebook
Troubleshooting IBM ThinkPad A31 monitor problem
The system is having problems with the graphics drivers, heres how to tell!!! when you first turn the machine on display is clear until it gets to windows. To resolve the problem is quite easy, just reboot into safe mode and un-install the graphics drivers, then reboot. When the system restarts is should re-install the graphics drivers automaticaly for you, job done :)
keep me informed please
regards
Nov 24, 2008 | Computers & Internet
Gateway Table PC Cx2620 Screen Wobble
Unplug and remove the battery pack for safety. DOn't want any shorts to happen. With the laptop open, gently pry with a very small blade the plastic cover at the front of the swivel and remove. It is in two pieces...front and back. It is OK to leave the rear half in place. Once removed you must close the laptop again. You will now have access to the screws on the hinges. Use a small Robertson screwdriver to tighten the screws. Snap the cover back in place....Voila!. IF the screws are broken (like mine were) remove all the good screws, gently lift and move the screen slightly forward, remove the broken screws with some needle nose pliers. Reassemble with new screws. I found some screws at the local computer geek shop in his selection of random screws. THey are quite tiny. CHeck Future Shop if they are in your area as they deal and repair Gateway so you may have a better chance of finding some screws that work. Good Luck.
Nov 18, 2008 | Gateway Convertible CX2620 Notebook
Toshiba laptop a105 dead screen
it looks like the power supply for the light on the lcd screen os disconnected.If you can go deper to dissassemble the laptop you will find the connectors(like small plugs).check all the wires connecting to the screen.
Oct 04, 2008 | Toshiba Satellite A105 Notebook
Sony Playstation 3 (PS3) Console Logo
87 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
