Question about Bosch Axxis WFL 2060 Front Load Washer
What holes which holes on the servis ecocare 1000 do i put the different liquids like the comfort and stuff
    Problem Solver:
  • 9 Answers
Open the drawer at the top left of the front of your machine: you will see 3 compartments: right is prewash, middle is for softener, left is for wash. WATCH OUT- these machines do not need as much washing powder as the american models-putting too much soap could damage your machine and lenghthen the cycles.... I use half of what I used in my previous american washer.... do not be surprised either by the spinning cycle: before going full blown into spinning the machine has sensors that perit autobalancing of the laundry. You must not load laundry above 3/4 of the diameter of the drum.
Posted on Jul 27, 2009
How do you descale
usually with a white vinegar cycle
Mar 30, 2015 | Saeco Magic Comfort Plus Espresso Machine
Servis wp1249f2w leaving powder in the drawer each time, any solutions?
Stop using powder. Use liquid instead and see if that makes a difference.
First off. Before changing the detergent clean the residue of the powder from the tray.
Another thing to keep in mind is the type of detergent.
You want HE detergent. The reason for HE is it uses less and leaves nothing behind. ( HE stands for High Efficiency detergent.)
Hope this helped.
Mar 09, 2015 | Washing Machines
WHAT IS THE DIFFERENCE BETWEEN MG AND ML
A Milligram is MG and a Milliliter is a ML. (MG) is used in dry measure and (ML) is used in liquid measure
1000 micrograms (mcg) EQUALS 1 milligram (mg)
1000 milligrams (mg) EQUALS 1 gram (g)
1000 grams (g) EQUALS 1 kilogram (kg)
1 kilogram (kg) EQUALS 2.2046 pounds
1 ounce EQUALS 28.35 grams
1 pound EQUALS 0.4536 kilograms
1 pound EQUALS 16 ounces
16 ounces EQUALS 453.6 grams
1000 milliliters (mL) EQUALS 1 liter (L)
1 liter (L) EQUALS 1.0567 quarts liquid
1 quart liquid EQUALS 0.9463 liter
4 quarts EQUALS 1 gallon
Jun 28, 2014 | Health & Beauty
I need new thermostat for servis tumble dryer m2007blk cant find anyone that stocks them servis gone to liquidation
try:
http://www.spares2go.co.uk/browse-M200-Tumble_Dryer-SERVIS-spares-m164-p5630.htm
Nov 25, 2010 | Dryers
I need to adjust my front brake handle. I would
If you want to move the whole lever assembly, remove the plastic allen bolt covers, insert the proper allen head (10?) unscrew, and adjust for your comfort. Most models have a pin located on the lever, that rests in a hole on the handle bars to keep it from slipping while riding. If this is the case, you can not move them without grinding off the pin locator.
May 01, 2010 | 2001 Suzuki GSX-R 1000
My servis washing machine wont take in softner
Try a "good quality" name brand liquid softener. Some softeners out there are real thick and settle out to be paste. This problem was encountered by me and since I changed to a real liquid, it went away.
Oct 24, 2009 | Washing Machines
Servis ecocare 1000, spinning to fast on aggitate,
It sounds like the speed control is acting up that controls the speed of the motor..
This is usually built into the main control board, and means replacing the unit. the only other possibility , is if the motor has a thing called the tacho magnet,this is to be found on the end of the motor away from the drive pully.
What you are looking for is a round magnet about 20mm in diameter, if there is one, check to see if it is loose or broken as this can effect the speed of the motor.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Changing door gasket on Servis M9813s washer dryer
you can clean in situ just as good as if you remove it
Jul 12, 2008 | Washing Machines
Too much soap???
One way or another - you're going to have to get that comforter into a spin cycle to get the water out of it. Otherwise it won't dry out until June. If there's excess soap when the cycle finishes, run another full wash without soap. If the washer won't drain properly with the comforter inside, you have another problem altogether.
Mar 16, 2008 | Creda W100FW Front Load Washer
Servis washing machine
the bushes might look ok but they only last a year and a half tops thats wat it sounds like to me if it cant spin right
Mar 03, 2008 | Kenmore 22422 Top Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
212 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
