Canon work center 5755 print black stain how can remove
1 Related Answer
fotomohamed
mohamed salim shaikh
  • 321 Answers
  • Posted on Jun 18, 2009
SOURCE: black stains on the printed sheet
use deep head clean
2answers
My Canon Pixma MP170 printer is not printing properly after I had to reset it.
The Waster Ink Absorber, does just that. When you switch the printer on a small amount of ink is forced through the nozzles in preparation for printing. When you Deep Clean, more ink is pulsed through. It doesn't alter print quality, so if it is not printing 'properly', the cause is something else. On most Canon MP, you can remove the cartridge holder and run hot water through it. Blot with tissue until there is no ink staining. You can get them serviced locally at a Canon Service Centre.
Xerox 5755 prinnt quality low i mean print is light very tryng but print is a not set
Kindly provide solution of wavy print in xerox 5755.
Whatsapp 00923334298796
Canon pixma ip1000 printer prblem
Remove the printer software. And remove the driver from device manager "usb printing support" .and remove printer from control panel>printers, and download latest driver from Internet and install. It will work, if not contact service centers with your printer
Just printing blank pages, help!
Please remove your Color/Black catridge and check the head. The head must be blocked by dirty inks. Rub the head tightly with soft paper/toilet paper until the ink stain on the paper... afterall your printer is ready to use.... thanks
1helpful
Big black vertical line on back of the paper.PIXMA CanoniP4200
Your black ink seems to have spilled a bit at the nozzle. The fact is even if you do nothing it should seize staining the back of the paper after a while, so long as the spill is only temporal. But if you want it over with quickly, you may try printing quite good number of pages till you see that the stops. With every print you will most certainly observe that the stain will reduce. Otherwise if you can reach into the printer with a stick or something, you may try to clean it.
All of a sudden my Canon MP830 is printing only very light, unclear very light black lines on the chapter of my dissertation I am trying to print. All the ink tanks are full & I've done 2 deep...
Doesn't matter if the ink tanks are full. They may also have dry ink on headers. You could try to draw a black rectangle in MS Paintor any other software and try to print it at the best quality. You also could try to remove the black cartridge and see if it leave a ink stain on a absorbant paper (like a napkin). If does not leave a ink stain it means that the ink is dry.
If this is the case you may try to boil some water. When the water is boiled take it away from the fire and sink the cartridge into the boiled water and keep it there until the water cool down.
1helpful
Replaced Yellow Cartridge, Red light on, close lid, not working,
Hi ...
I would suggest that you follow the below stesp to install the ink tank ..
. Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
Note: If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2. Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3. Remove the ink tank whose lamp is flashing fast or is off.
Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Caution: Handle ink tanks carefully to avoid staining clothing or the surrounding area. Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
Note: Be sure to replace ink tanks one by one when replacing more than one ink tank.
4. Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
Unpack the new ink tank and completely pull off the orange tape. Then, remove the film. Remove the orange protective cap from the bottom of the ink tank and discard it.
Important:
  • Be sure to remove the clear film from the ink tank in the exact order shown in step 4, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
  • Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
  • Do not re-attach the protective cap once you have removed it.
  • Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
  • Ink on the removed protective cap may stain your clothes and hands.
  • Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5. Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important: Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6. Close the Inner Cover.
Note: Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7. Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
  • The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
  • To maintain optimal print quality, use an ink tank within six months of first use.
  • Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
  • Color ink consumption may occur even when black-and-white or gray scale printing is specified.
    Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
  • When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Don't forget to vote if this helps ... Cheers :)
Just purchased a Canon MX700 all-in-one printer and everything seems to work except it won't print black on anything...please help
1- check the cartridge- did you remove the plastic film-
2- get a piece of tissue and put the cartridge on it, does it stain the tissue? if yes it's o.k. if no, it's dry : change
3- clean contacts
4- exchange printer.
1helpful
5answers
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
2helpful
2answers
Canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
old marine
old marine
ZJ Limited
ZJ Limited
