SOURCE: Water running through overflow
No, Do you mean that water is draining outside when it is running, if so, no need to be concerned. Yes yes yes be concerned if it is draining on to the ceiling.Get up there and ck the drain make sure the pan is tilted right to drain. ck the drain out side make sure it is free to flow. .
SOURCE: the water drains too fast and overflows
Any washer cannot drain too fast, the problem is in your drainage pipework, there is likely to be a partial blockage or restriction of some kind, it means rodding the pies, or taking it apart to clean it.
Here is a tip that will help you with that problem...
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
SOURCE: GE Water Cooler Reservoir overflows.
There should be no crack or pin hole in your water bottle.
Water bottle should be air-tight to make proper pressure inside bottle.
Whenever lose pressure, water overflow with no bubble.
Just replace water bottle with no crack or pin hole.
Good luck.
leey05
